Subject: Re: Channel Archiver compilation error
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Tue, 19 Dec 2017 14:13:53 +0100
Hi Micheal,
Thanks for the changes you made.
I created a docker with Debian GNU/Linux 7
Installed the debian-packages from the repo at NSLS2:
ii  channelarchiver                  2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
ii  channelarchiver-dataserver       2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
ii  channelarchiver-dev              2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
ii  channelarchiver-engine           2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
ii  channelarchiver-tools            2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
ii  libchannelarchiver1              2.9.2+dfsg-19                    amd64        The EPICS data archiving engine
add protbuf related packages:
ii  libio-socket-ip-perl             0.16-2                           all          module for using IPv4 and IPv6 sockets in a protocol-independent way
ii  liblwp-protocol-https-perl       6.03-1                           all          HTTPS driver for LWP::UserAgent
ii  libprotobuf-dev                  2.4.1-3                          amd64        protocol buffers C++ library (development files)
ii  libprotobuf-lite7                2.4.1-3                          amd64        protocol buffers C++ library (lite version)
ii  libprotobuf7                     2.4.1-3                          amd64        protocol buffers C++ library
ii  libprotoc7                       2.4.1-3                          amd64        protocol buffers compiler library
ii  libtelnet2                       0.21-1                           amd64        Small library for parsing the TELNET protocol - shared library
ii  protobuf-c-compiler              0.14-1+b1                        amd64        protocol buffers C compiler
ii  protobuf-compiler                2.4.1-3                          amd64        compiler for protocol buffer definition files
I could compile and run ca2aa
./exportall.py /FELatFHI/FELarchive/radiationSafety/2016/year_index /FELatFHI/AA/
with success.
Heinz
> On 19. Dec 2017, at 02:48, Michael Davidsaver <[email protected]> wrote:
> Unfortunately I've only ever built ca2aa against the debian package repo for
> channelarchiver.  I just verified that, after making some gcc6 and Base3.15 changes,
> it and ca2aa build, and ca2aa passes tests.
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Channel Archiver compilation error Wang, Lin
Re: Channel Archiver compilation error Michael Davidsaver
Re: Channel Archiver compilation error Heinz Junkes
Prev: Helium Purity Sensors austen.rose
Next: Re: Puzzled with lockset(?) problem Dirk Zimoch
Prev: Re: Channel Archiver compilation error Michael Davidsaver
Next: Puzzled with lockset(?) problem Dirk Zimoch
