1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VisualDCT not starting on RHEL7
To: <[email protected]>
Date: Tue, 19 Dec 2017 11:05:09 -0600
Hi Ralph,
On 12/19/2017 10:32 AM, Ralph Lange wrote:
> On RHEL7 (7.3 and 7.4), VisualDCT immediately quits when configured to
> load DBDs at start.
Have you tried a different DBD file? Loading softIoc.dbd works for me
when it was built by Base-3.14 and 3.15, but not with 3.16 or 7.0.
> What we see:
> Moving our system from RHEL 6 to RHEL 7, the VisualDCT tool doesn’t
> correctly start up anymore. We set the dbd files to read at startup via
> an env variable, and VDCT seems to start up normally, but then bails out
> complaining that it did not load any DBDs:
> $ vdct
> Loading VisualDCT v2.6.1280...
> Directive to load DBD: '/opt/codac-6.0/epics/dbd/base.dbd'.
> Directive to load DBD: '/opt/codac-6.0/epics/dbd/pxi6259.dbd'.
> Directive to load DBD: '/opt/codac-6.0/epics/dbd/nisync.dbd'.
> Directive to load DBD: '/opt/codac-6.0/epics/dbd/nisync-generalTime.dbd'.
> No DBD loaded! Exiting...
Here's what I get with 3.16:
> tux% vdct dbd/softIoc.dbd
> Directive to load DBD: 'dbd/softIoc.dbd'.
However with 3.15:
and the window opens as expected.
Interestingly even softIocPVA.dbd works when using the earlier Base
releases:
> tux% pwd
> /local/anj/v4/bundleCPP/pva2pva
> tux% vdct dbd/softIocPVA.dbd
> Directive to load DBD: 'dbd/softIocPVA.dbd'.
I suspect VDCT doesn't like the link() entries that appeared in 3.16 DBD
files, but whether that's the cause of the crash I don't know. Then
there's the new JSON syntax that we now support in DB files for both
field() and info() statements...
> The DBD files are fine, the same jar that works on RHEL 6 shows this
> behaviour on RHEL 7. Java versions are different, but not that different
> (1.8.0_101 vs. 1.8.0_141).
My machine got patched recently, so my java is newer than either of
yours, but I doubt that's the cause of your crashes:
> tux% java -version
> openjdk version "1.8.0_151"
> OpenJDK Runtime Environment (build 1.8.0_151-b12)
> OpenJDK 64-Bit Server VM (build 25.151-b12, mixed mode)
HTH,
- Andrew
VisualDCT not starting on RHEL7 Ralph Lange
Prev: VisualDCT not starting on RHEL7 Ralph Lange
Next: APS EPICS Website Moved Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
