1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: usage of updatePVs in pcaspy
To: Wang Xiaoqiang <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 30 Dec 2017 09:44:57 -0800
On Fri, Dec 29 2017, Jameson Graef Rollins <[email protected]> wrote:
> The peculiar thing I'm worried about is that in my current application
> there are, under some circumstances, multiple record updates during a
> single driver.write().  For example, before pcaspy 0.7.0, I was doing
> something like this:
> class MyDriver(pcaspy.Driver):
>     def write(self, channel, value):
>         self.setParam(channel, value)
>         self.setParam(other_channel, other_value)
>         self.pvDB[channel].flag = False
>         self.updatePVs()
>         return True
> The 'pvDB[channel].flag = False' was to prevent subscribed clients from
> seeing multiple updates for the primary record 'channel'.  In 0.7.0, it
> seems that neither that, nor the final updatePVs() call are necessary.
> However, I am now occasionally (less than 50% of the time) seeing
> multiple client updates for the primary channel.  The sporadic nature of
> the double updates makes me think there's some kind of race condition.
> Regardless, I can't figure out what's going on, and how to uniformly
> prevent redundant update in subscribed clients.
Xiaoqiang, I just sent a pull request for a patch that seems to fix this
issue for me [0]:
https://github.com/paulscherrerinstitute/pcaspy/pull/49
There is a race condition between the SimplePV.updateValue() calls in
the PV scan() method, and in the Driver.updatePV() method.  The above
patch is a work around for the issue and seems to eliminate the
occasional double updates that I was seeing in my test suite.
This does *not* fix the other issue that I mention in the other thread,
that I see spurious updates after initialization.
jamie.
Attachment: signature.asc
Description: PGP signature
usage of updatePVs in pcaspy Jameson Graef Rollins
Prev: Re: usage of updatePVs in pcaspy Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
