1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: void return value in RPC
To: <[email protected]>
Date: Fri, 5 Jan 2018 17:19:27 +0100
On 01/04/2018 07:08 PM, Michael Davidsaver wrote:
> On 01/03/2018 09:34 PM, renato sanhueza wrote:
>> I am toying with pvAccess and I want to implement a RPC that
>> returns nothing (void). Reading the Java API I found that all RPC
>> should return a PVStructure. I tried to return an un-instantiated
>> PVStructure, but sending a Null causes an exception. What would be
>> the best way of implement a void method?
> A Structure need not have any members.  An empty structure is as
> close to void as the PVData type system supports.
It depends on what you expect of the void data type.
An empty structure (as a type) has exactly one value: the empty
structure. This is not the same as void in C/C++, which has /no/ value
at all (you cannot assign the result of a function that returns void to
a variable). I may remember this wrongly, but I thought pvData also
supports (tagged) unions. I would say that an empty /union/, i.e. one
with no choices at all, more faithfully represents the C/C++ void.
I am pretty much aware that the distinction is mostly academic and not
of much practical relevance... ;-)
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
void return value in RPC renato sanhueza
Re: void return value in RPC Michael Davidsaver
Prev: Re: Build pvaPy for Python 3 Siniša Veseli
Next: Re: Build pvaPy for Python 3 renato sanhueza
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: void return value in RPC Michael Davidsaver
Next: Build pvaPy for Python 3 renato sanhueza
ANJ, 05 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
