Hi, This is probably a newbie question. I have built EPICS base and EPICS 4.6.0 modules following the instructions in the README files. But I notice that gcc doesn't know where the headers are. The linker doesn't know either. So when I compile a program using pv/pvAccess I get an error (of course). I found that I can add the paths to $CPLUS_INCLUDE_PATH and $LD_LIBRARY_PATH manually for fixing the errors. The path to my EPICS base is: /opt/epics/base The path to EPICS v4 modules is: /opt/epics/EPICS-CPP-4.6.0 But if I want to compile a program I will have to add many subdirectories of the previously mentioned directories manually. Best regards, -- Renato Sanhueza Ulsen
Ing Civil Informática.
| ANJ, 07 Jan 2018 |
Home
News
About
Talk
Base
Modules
Extensions
