1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Telling gcc the location of EPICS
To: renato sanhueza <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 7 Jan 2018 17:44:26 +0000
Hi Renato,
You need to put each of the EPICS 4.6.0 modules in your application's configure/RELEASE file.  For example:
EV4_BASE=/corvette/usr/local/epics/epicsV4/EPICS-CPP-4.6.0
PVCOMMON=$(EV4_BASE)/pvCommonCPP
PVACCESS=$(EV4_BASE)/pvAccessCPP
PVDATA=$(EV4_BASE)/pvDataCPP
PVDATABASE=$(EV4_BASE)/pvDatabaseCPP
NORMATIVETYPES=$(EV4_BASE)/normativeTypesCPP
EPICS_BASE=/corvette/usr/local/epics/base-3.15.5
The EPICS build system will search all modules listed in configure/RELEASE for include files, dbd files, library files, etc.
From: [email protected] <[email protected]> on behalf of renato sanhueza <[email protected]>
Sent: Sunday, January 7, 2018 11:04 AM
To: [email protected]
Subject: Telling gcc the location of EPICS
This is probably a newbie question. I have built EPICS base and EPICS 4.6.0 modules following the instructions in the README files. But I notice that gcc doesn't know where the headers are. The linker doesn't know either. So when I compile a program using pv/pvAccess I get an error (of course). I found that I can add the paths to  $CPLUS_INCLUDE_PATH and $LD_LIBRARY_PATH manually for fixing the errors.
Is there a more practical way to do it?
The path to my EPICS base is: /opt/epics/base
The path to EPICS v4 modules is: /opt/epics/EPICS-CPP-4.6.0
But if I want to compile a program I will have to add many subdirectories of the previously mentioned directories manually.
Best regards,
Renato Sanhueza Ulsen
Ing Civil Informática.
Telling gcc the location of EPICS renato sanhueza
Prev: Telling gcc the location of EPICS renato sanhueza
Next: compress record FIFI/LIFO not working Daniel Schick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
