Hi all,
I am currently using epics base 3.16.1 and I have a problem with the compress record used as ring buffer.
In both, Epics 3.16.1 and 7.0 the update of the ring buffer is not FIFO or LIFO but happens somewhere in the middle of the array.
When I use the latest 3.15 branch everything works fine.
Here is an example of my test db-file and the output from camonitor:
record(calc,"counter") {
field(CALC,"VAL+1")
field(SCAN,"1 second")
record(compress,"ring") {
field(DESC, "test")
field(NSAM,"10")
field(ALG,"Circular Buffer")
field(INP,"counter")
field(BALG,"LIFO")
field(PREC,"1")
with epics 3.15 it is fine:
~ $ camonitor ring
ring *** Not connected (PV not found)
ring 2018-01-08 12:55:16.628324 8 0 1 2 3 4 5 6 7
ring 2018-01-08 12:55:17.628331 9 0 1 2 3 4 5 6 7 8
ring 2018-01-08 12:55:18.628323 10 0 1 2 3 4 5 6 7 8 9
ring 2018-01-08 12:55:19.628330 10 1 2 3 4 5 6 7 8 9 10
ring 2018-01-08 12:55:20.628326 10 2 3 4 5 6 7 8 9 10 11
ring 2018-01-08 12:55:21.628331 10 3 4 5 6 7 8 9 10 11 12
ring 2018-01-08 12:55:22.628327 10 4 5 6 7 8 9 10 11 12 13
ring 2018-01-08 12:55:23.628324 10 5 6 7 8 9 10 11 12 13 14
ring 2018-01-08 12:55:24.628325 10 6 7 8 9 10 11 12 13 14 15
ring 2018-01-08 12:55:25.628332 10 7 8 9 10 11 12 13 14 15 16
ring 2018-01-08 12:55:26.628326 10 8 9 10 11 12 13 14 15 16 17
ring 2018-01-08 12:55:27.628330 10 9 10 11 12 13 14 15 16 17 18
ring 2018-01-08 12:55:28.628323 10 10 11 12 13 14 15 16 17 18 19
ring 2018-01-08 12:55:29.628325 10 11 12 13 14 15 16 17 18 19 20
ring 2018-01-08 12:55:30.628327 10 12 13 14 15 16 17 18 19 20 21
ring 2018-01-08 12:55:31.628331 10 13 14 15 16 17 18 19 20 21 22
ring 2018-01-08 12:55:32.628327 10 14 15 16 17 18 19 20 21 22 23
with epics 3.16 and 7.0 I get the wired update behaviour:
~ $ camonitor ring
ring 2018-01-08 14:23:50.889595 2 0 1
ring 2018-01-08 14:23:51.889598 3 0 1 2
ring 2018-01-08 14:23:52.889594 4 0 1 2 3
ring 2018-01-08 14:23:53.889596 5 0 1 2 3 4
ring 2018-01-08 14:23:54.889603 6 0 1 2 3 4 5
ring 2018-01-08 14:23:55.889601 7 0 1 2 3 4 5 6
ring 2018-01-08 14:23:56.889594 8 0 1 2 3 4 5 6 7
ring 2018-01-08 14:23:57.889598 9 0 1 2 3 4 5 6 7 8
ring 2018-01-08 14:23:58.889592 10 6 7 8 9 0 1 2 3 4 5
ring 2018-01-08 14:23:59.889607 10 7 8 9 10 1 2 3 4 5 6
ring 2018-01-08 14:24:00.889598 10 8 9 10 11 2 3 4 5 6 7
ring 2018-01-08 14:24:01.889599 10 9 10 11 12 3 4 5 6 7 8
ring 2018-01-08 14:24:02.889596 10 10 11 12 13 4 5 6 7 8 9
ring 2018-01-08 14:24:03.889594 10 11 12 13 14 5 6 7 8 9 10
ring 2018-01-08 14:24:04.889598 10 12 13 14 15 6 7 8 9 10 11
ring 2018-01-08 14:24:05.889596 10 13 14 15 16 7 8 9 10 11 12
ring 2018-01-08 14:24:06.889597 10 14 15 16 17 8 9 10 11 12 13
ring 2018-01-08 14:24:07.889598 10 15 16 17 18 9 10 11 12 13 14
ring 2018-01-08 14:24:08.889595 10 16 17 18 19 10 11 12 13 14 15
ring 2018-01-08 14:24:09.889616 10 17 18 19 20 11 12 13 14 15 16
ring 2018-01-08 14:24:10.889598 10 18 19 20 21 12 13 14 15 16 17
ring 2018-01-08 14:24:11.889599 10 19 20 21 22 13 14 15 16 17 18
ring 2018-01-08 14:24:12.889595 10 20 21 22 23 14 15 16 17 18 19
thanks and best wishes
Daniel
____________________
Dr. Daniel Schick
Max-Born-Institute
for nonlinear optics
and short pulse spectroscopy
im Forschungsverbund Berlin e.V.
Max-Born-Str. 2a
12489 Berlin, Germany
Room: House B, 3.3
Tel.: +49 30 6392 1311
- Re: compress record FIFI/LIFO not working Michael Davidsaver
Re: Telling gcc the location of EPICS Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
