| Dear all,
I have a question regarding recovering data archived by epics using mysql. I use a python code to automatically recover and analyse a set of data. Some of these data are constant and compressed by EPICS so when I extract them with respect to a given data stamp, it gives “nan”. The only way to get value is to have a variation. Looping the time stamps is not feasible as I can easily miss the right time stamp. Do you of of any way that could allow to directly extract constant compressed data ?
Here is the code I use for the extraction :
def db_fetch1(variable, time1, time2): import pymysql import numpy as np conn = pymysql.connect(host='accmysqlslv', port=3306, user='archive', passwd='archive', db='archive2') cur = conn.cursor() command = "select float_val from sample s where s.channel_id = (select channel_id from channel where name = '" + variable + "') and smpl_time >= '" + time1 + "' and smpl_time < '"+ time2 + "'" cur.execute(command) output = [] for row in cur: if np.isreal(row[0]) == True: output.append(row[0]) cur.close() conn.close() output = np.array(output,dtype=float) return output
Thank you,
Best regards, Adnan Ghribi
CNRS - GANIL PhD, Adnan GHRIBI | |
signature.asc
Description: Message signed with OpenPGP
- Re: EPICS data extraction with mysql and compressed data Kasemir, Kay
Re: compress record FIFI/LIFO not working Michael Davidsaver
Example for User Created File Types in the build system Jeong Han Lee
<2018>
2025
2026
Re: compress record FIFI/LIFO not working Daniel Schick
<2018>
2025
2026
ANJ, 13 Apr 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
