1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Example for User Created File Types in the build system
To: Benjamin Franksen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Jan 2018 15:59:34 +0100
Hi Ben,
  * Could you see $(INSTALL_LOCATION)/abc directory after make?
  * Could you see two files in that abc directory?
  * Could you delete $(INSTALL_LOCATION)/abc directory with make distclean?
If so, I will test them again with "fresh" installation of each bases and sorry about it.
   Best,
   Han
On 01/09/2018 02:05 PM, Benjamin Franksen wrote:
On 01/09/2018 10:58 AM, Jeong Han Lee wrote:
   I've followed old tech-talk at
https://epics.anl.gov/tech-talk/2016/msg00866.php in order to use User
Created File Types, by the suggestion of Ralph.
   It works well with EPICS BASE 3.16.1, but it doesn't work with BASE
3.15.5, even if 3.15.5 documentation contains this feature. I looked
some of BASE configuration files (especially FILE_TYPE)
   I have the example and dummy repository for this evaluation as follows:
   https://github.com/jeonghanlee/epics-abc
   Could you help me to figure out how to resolve them with EPICS 3.15.5?
I have tried your example and it works for me with the HEAD of 3.15 branch.
Cheers
Ben
Re: Example for User Created File Types in the build system Benjamin Franksen
Example for User Created File Types in the build system Jeong Han Lee
Prev: Re: asynUInt32DigitalClient constructor Mark Rivers
Next: Re: EPICS data extraction with mysql and compressed data Ghribi Adnan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Example for User Created File Types in the build system Benjamin Franksen
Next: Re: Example for User Created File Types in the build system Benjamin Franksen
ANJ, 09 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
