1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Scan - Set values
To: EPICS Tech Talk <[email protected]>
Date: Tue, 23 Jan 2018 14:12:34 +0100
On Tue, Jan 23, 2018 at 10:13 AM, Anton Derbenev <[email protected]> wrote:
> It worth mentioning that even though my simulation IOCs are relatively heavy
> on amount of computations they do (lots of chained waveform calculations and
> aSubs), they work very well even on x100 rate without any apparent issues. I
> don't know what is the lowest scan rate achievable with the described method
> though. I guess minimal reasonable value depends on an application.
Technically, the lowest reasonable SCAN rate is limited by the
resolution of the system timer.
(Historically, the VxWorks clock was ticking at 60Hz, so 10Hz was a
reasonable choice.)
If you are able to run an IOC application using a fast rate obviously
depends on the application and the CPU power of the machine the IOC is
running on.
Note for multi-core machines: while running multiple callback threads
(that do 'I/O Intr' processing) in parallel has been available for a
while, there is still one periodic scan thread per SCAN period. Adding
support for parallel SCAN threads is conceptionally possible, but
needs work to be done (or funded).
Cheers,
~Ralph
Re: PV Scan - Set values Anton Derbenev
Prev: Re: How to work with motor record position counts larger than 2147483648? Torsten Bögershausen
Next: Training Class March 5-9, Long Island NY, Topic: EPICS 7 Application Development in Python Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV Scan - Set values Anton Derbenev
ANJ, 23 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
