1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: device support for bidirectional records
Date: Wed, 24 Jan 2018 21:09:04 +0000
I was wondering if there is a current recommended method for implementing device support for bidirectional records. That is, records that both write values that are obtained through EPICS to a device and also update their value to reflect the status of the device when it changes through means outside of EPICS.
On a related note, are there versions of the standard output records (bo, ao, longout, etc.) that have a separate readback field in engineering units?
Thank you for your time,
Patrick
RE: device support for bidirectional records Mark Rivers
Re: device support for bidirectional records Michael Davidsaver
Prev: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Michael Davidsaver
Next: RE: device support for bidirectional records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Career Opportunity White, Karen S.
ANJ, 24 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
