On 01/24/2018 01:09 PM, Thomas, Patrick wrote:
> Hi,
> I was wondering if there is a current recommended method for implementing device support for bidirectional records. That is, records that both write values that are obtained through EPICS to a device and also update their value to reflect the status of the device when it changes through means outside of EPICS.
Not really. I don't have any example to show you because I go out of my way to avoid having bi-directional setting records.
This turns out to be thorny problem if you want to be certain to avoid all possible races, and depends on how the underlying
communications/hardware works. My preference is to have separate setting and readback records.
At core, your device support needs to have an internal flag to indicate why it is processing.
Whether for a new setting, or to synchronize. See my comments on https://github.com/epics-modules/asyn/issues/56
The discussion on this issue, and the related pull request, may give you an idea of why it is
so hard to avoid races when asynchronous communications are involved.
What is comes down to is that synchronizing a true multi-master system is difficult to do entirely in software,
and EPICS doesn't have a generic solution.
> On a related note, are there versions of the standard output records (bo, ao, longout, etc.) that have a separate readback field in engineering units?
> Thank you for your time,
> Patrick
- device support for bidirectional records Thomas, Patrick
RE: device support for bidirectional records Mark Rivers
More streamDevice and Asyn issues... Rod Nussbaumer
<2018>
2025
2026
<2018>
2025
2026
