1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC build
To: 'Vishnu Patel' <[email protected]>, techtalk <[email protected]>
Date: Thu, 25 Jan 2018 17:43:05 +0000
Hi Vishnu,
I just tried what you did and it worked for me:
J:\epics\devel\test>h:\epics-devel\base-7.0.1\bin\win32-x86-static\makeBaseApp.pl -t ioc test
J:\epics\devel\test>h:\epics-devel\base-7.0.1\bin\win32-x86-static\makeBaseApp.pl -t ioc -i test
The following target architectures are available in base:
    linux-x86
    vxWorks-ppc32
    linux-x86_64
    windows-x64-static
    windows-x64
    win32-x86-static
    windows-x64-static-vs2015
    windows-x64-static-vs2017
    windows-x64-vs2015
    win32-x86-static-vs2017
    win32-x86-vs2017
What architecture do you want to use? win32-x86-static
The following applications are available:
    test
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name? test
J:\epics\devel\test>make
make -C ./configure install
make[1]: Entering directory 'J:/epics/devel/test/configure'
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86-static -f ../Makefile TOP=../.. \
    T_A=win32-x86-static install
make[2]: Entering directory 'J:/epics/devel/test/configure/O.win32-x86-static'
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/convertRelease.pl checkRelease
make[2]: Leaving directory 'J:/epics/devel/test/configure/O.win32-x86-static'
make[1]: Leaving directory 'J:/epics/devel/test/configure'
make -C ./testApp install
make[1]: Entering directory 'J:/epics/devel/test/testApp'
make -C ./src install
make[2]: Entering directory 'J:/epics/devel/test/testApp/src'
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/makeMakefile.pl O.win32-x86-static ../../..
make -C O.win32-x86-static -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'J:/epics/devel/test/testApp/src/O.win32-x86-static'
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/mkmf.pl  -m testMain.d -I. -I../O.Common -I. -I. -I.. -I../../.
./include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc
-IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        testMain.obj ../testMain.cpp
"Creating dbd file test.dbd"
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -IH:/epics
-devel/base-7.0.1/dbd -o test.dbd base.dbd
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../
../dbd -IH:/epics-devel/base-7.0.1/dbd    -o test_registerRecordDeviceDriver.cpp ../O.Common/test.dbd test_registerRecor
dDeviceDriver J:/epics/devel/test
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/mkmf.pl  -m test_registerRecordDeviceDriver.d -I. -I../O.Common
-I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics-devel/base-7.0.
1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include        test_reg
isterRecordDeviceDriver.obj test_registerRecordDeviceDriver.cpp
"Installing created dbd file ../../../dbd/test.dbd"
mkdir ../../../dbd
cl -EHsc -GR               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3
-w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../incl
ude/os/WIN32 -I../../../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc -IH:/epics-devel/base-7.0.1/include/os
/WIN32 -IH:/epics-devel/base-7.0.1/include        -c test_registerRecordDeviceDriver.cpp
/WIN32 -IH:/epics-devel/base-7.0.1/include        -c ../testMain.cpp
testMain.cpp
link -nologo   -incremental:no -opt:ref -release               -out:test.exe       test_registerRecordDeviceDriver.obj t
estMain.obj     H:/epics-devel/base-7.0.1/lib/win32-x86-static/dbRecStd.lib  H:/epics-devel/base-7.0.1/lib/win32-x86-sta
tic/dbCore.lib  H:/epics-devel/base-7.0.1/lib/win32-x86-static/ca.lib  H:/epics-devel/base-7.0.1/lib/win32-x86-static/Co
m.lib   ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
"Installing created executable ../../../bin/win32-x86-static/test.exe"
mkdir ../../../bin
mkdir ../../../bin/win32-x86-static
make[3]: Leaving directory 'J:/epics/devel/test/testApp/src/O.win32-x86-static'
make[2]: Leaving directory 'J:/epics/devel/test/testApp/src'
make -C ./Db install
make[2]: Entering directory 'J:/epics/devel/test/testApp/Db'
make[3]: Entering directory 'J:/epics/devel/test/testApp/Db/O.win32-x86-static'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory 'J:/epics/devel/test/testApp/Db/O.win32-x86-static'
make[2]: Leaving directory 'J:/epics/devel/test/testApp/Db'
make[1]: Leaving directory 'J:/epics/devel/test/testApp'
make -C ./iocBoot install
make[1]: Entering directory 'J:/epics/devel/test/iocBoot'
make -C ./ioctest install
make[2]: Entering directory 'J:/epics/devel/test/iocBoot/ioctest'
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/convertRelease.pl -t J:/epics/devel/test envPaths
perl -CSD H:/epics-devel/base-7.0.1/bin/win32-x86-static/convertRelease.pl -a win32-x86-static -t J:/epics/devel/test dl
lPath.bat
make[2]: Leaving directory 'J:/epics/devel/test/iocBoot/ioctest'
make[1]: Leaving directory 'J:/epics/devel/test/iocBoot'
Note that I am using base 7.0.1.1, while you are using 3.16.1.  But they are very similar.
I have seen those “Can’t open perl script” errors before, but I don’t recall under what circumstances.
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: Thursday, January 25, 2018 11:19 AM
To: techtalk <[email protected]>
Subject: IOC build
Hi ALL,
I tried to develop IOC application on windows with Visual studio.
c:\epics\Devlop\test>"..\..\base-3.16.1\bin\win32-x86\makeBaseApp.pl" -t ioc test
c:\epics\Devlop\test>"..\..\base-3.16.1\bin\win32-x86\makeBaseApp.pl" -t ioc -i test
Using target architecture win32-x86 (only one available)
    test
c:\epics\Devlop\test>make
Can't open perl script ".": Permission denied
make: Entering directory `c:/epics/Devlop/test'
Can't open perl script "..": Permission denied
make[1]: Entering directory `c:/epics/Devlop/test/configure'
perl -CSD c:/epics/Devlop/test/configure/C:/epics/base-3.16.1/bin/win32-x86/makeMakefile.pl O.win32-x86 ../..
Can't open perl script "c:/epics/Devlop/test/configure/C:/epics/base-3.16.1/bin/win32-x86/makeMakefile.pl": Invalid argument
make[1]: *** [O.win32-x86] Error 22
make[1]: Leaving directory `c:/epics/Devlop/test/configure'
make: *** [configure.install] Error 2
make: Leaving directory `c:/epics/Devlop/test'
What additional configuration i need for making the IOC application on windows?
Thanks
Vishnu
IOC build Vishnu Patel
Prev: Re: asyn IP server port driver with streamDevice Rod Nussbaumer
Next: Re: Problems with scaler record on epics archiver Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: IOC build Vishnu Patel
Next: RE: IOC build freddie.akeroyd
ANJ, 25 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
