1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IOC build
To: <[email protected]>, <[email protected]>
Date: Thu, 25 Jan 2018 19:34:25 +0000
Hi Vishnu,
You seem to be getting an extra directory appended to the filename in:
    perl -CSD c:/epics/Devlop/test/configure/C:/epics/base-3.16.1/bin/win32-x86/makeMakefile.pl O.win32-x86 ../..
I don’t know if this has anything to do with “makeBaseApp.pl” being called using a relative path when you create the ioc?
If you start again but use
  c:\epics\base-3.16.1\bin\win32-x86\makeBaseApp.pl  -t ioc test
instead does it work any better?
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: 25 January 2018 17:19
To: techtalk
Subject: IOC build
Hi ALL,
I tried to develop IOC application on windows with Visual studio.
c:\epics\Devlop\test>"..\..\base-3.16.1\bin\win32-x86\makeBaseApp.pl" -t ioc test
c:\epics\Devlop\test>"..\..\base-3.16.1\bin\win32-x86\makeBaseApp.pl" -t ioc -i test
Using target architecture win32-x86 (only one available)
The following applications are available:
    test
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name? test
c:\epics\Devlop\test>make
Can't open perl script ".": Permission denied
make: Entering directory `c:/epics/Devlop/test'
make -C ./configure install
Can't open perl script "..": Permission denied
make[1]: Entering directory `c:/epics/Devlop/test/configure'
Can't open perl script "c:/epics/Devlop/test/configure/C:/epics/base-3.16.1/bin/win32-x86/makeMakefile.pl": Invalid argument
make[1]: *** [O.win32-x86] Error 22
make[1]: Leaving directory `c:/epics/Devlop/test/configure'
make: *** [configure.install] Error 2
make: Leaving directory `c:/epics/Devlop/test'
What additional configuration i need for making the IOC application on windows?
Thanks
Vishnu
IOC build Vishnu Patel
Prev: Re: Problems with scaler record on epics archiver Mooney, Tim M.
Next: RE: asyn IP server port driver with streamDevice Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: IOC build Mark Rivers
Next: asyn R4-33 available Mark Rivers
ANJ, 27 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
