1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with scaler record on epics archiver
To: "Mooney, Tim M." <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 Jan 2018 08:40:03 -0200
Hi Tim,
I already test your fix and it is working!
Thank you again.
Regards
On 25-01-2018 16:53, Mooney, Tim M. wrote:
Hi Mark,
The fix I'm testing posts all scaler values after updating the time stamp, and posts them with DBE_VALUE|DBE_LOG, regardless of whether any values are the same as when previously posted.  If nobody objects, I'll push this fix to github, and folks can see if it works for them.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
*Sent:* Thursday, January 25, 2018 12:37:45 PM
*To:* Mooney, Tim M.; Gabriel de Souza Fedel; [email protected]
*Subject:* RE: Problems with scaler record on epics archiver
Hi Tim,
It seems like the timestamps also need work.  If I monitor the S1 field the timestamp never updates to the value when the scaler finished counting.  It is always the time when the scaler finished counting on the previous count cycle. This is not what one would expect.
*From:*[email protected] [mailto:[email protected]] *On Behalf Of *Mooney, Tim M.
*Sent:* Thursday, January 25, 2018 11:48 AM
*To:* Gabriel de Souza Fedel <[email protected]>; [email protected]
*Subject:* Re: Problems with scaler record on epics archiver
I think the problem is that the scaler record doesn't post values with the attribute DBE_LOG, and the archiver probably subscribes only to posts with DBE_LOG.  I'm not sure what is the best solution, but it's probably one of these two:
- when the scaler finishes counting, post scaler values with DBE_LOG
- when the scaler finishes counting, post scaler values with DBE_LOG if they are not the same as the last time the values were posted with DBE_LOG.
Tim Mooney ([email protected] <mailto:[email protected]>) (630)252-5417
Beamline Controls Group (www.aps.anl.gov <http://www.aps.anl.gov>)
*From:*[email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>> on behalf of Gabriel de Souza Fedel <[email protected] <mailto:[email protected]>>
*Sent:* Thursday, January 25, 2018 4:51:42 AM
*To:* [email protected] <mailto:[email protected]>
*Subject:* Problems with scaler record on epics archiver
I'm having problems with scaler record on epics archiver.
Archiver doesn't record values from this PVs, just the first value (when
start archiving).
I tried to change to scan mode and didn't work too.
I'm think the problem is related to scaler timestamp behavior (the
timestamp doesn't change when PV is counting).
Has anyone had problems like this?
Regards
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] <mailto:[email protected]> | +55 (19) 3512 1226
www.lnls.cnpem.br <http://www.lnls.cnpem.br>
Gabriel Fedel
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Problems with scaler record on epics archiver Gabriel de Souza Fedel
Re: Problems with scaler record on epics archiver Mooney, Tim M.
RE: Problems with scaler record on epics archiver Mark Rivers
Prev: Re: Problems with scaler record on epics archiver Gabriel de Souza Fedel
Next: Re: IOC error Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problems with scaler record on epics archiver Shankar, Murali
ANJ, 26 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
