Hi:
You're right that when I create this record:
record(longin, "long")
then 'cainfo' will report
Native data type: DBF_LONG
while CAJ shows a DBR_INT.
Still, the CAJ DBR_*_INT types provide Java int[] for the value, which is 32 bit numbers. When I
caput long 2147483647
I do see that number in a CAJ client, it's not truncated to 16 bits as you would get with the C-client DBR_INT.
For the C client API, DBR_INT is the same as DBR_SHORT, and all of DBR_SHORT, INT, LONG exist in the API.
For the Java client, DBR_INT is basically DBR_LONG, and DBR_LONG has not been defined since it's already handled by DBR_INT..
-Kay
From: [email protected] <[email protected]> on behalf of Ryan Slominski <[email protected]>
Sent: Monday, January 29, 2018 2:02 PM
To: [email protected]
Subject: Java API JCA / CAJ DBR_LONG
It appears the Java API to EPICS does not include DBR_LONG type (missing from source: https://github.com/epics-base/jca/blob/master/src/core/gov/aps/jca/dbr/DBRType.java). When I use caget and probe on a DBR_LONG PV and compare with programmatic fetch the values don't match and Java reports the type as DBR_INT. Maybe I'm overlooking something. Any tips on having Java API return same value as command line tools?
- Java API JCA / CAJ DBR_LONG Ryan Slominski
Re: Java API JCA / CAJ DBR_LONG Miroslav Pavleski
<2018>
2025
2026
<2018>
2025
2026
