1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Java API JCA / CAJ DBR_LONG
To: Miroslav Pavleski <[email protected]>
Cc: [email protected]
Date: Mon, 29 Jan 2018 17:49:14 -0600
On 01/29, Miroslav Pavleski wrote:
> My colleague Matej Sekoranja has the answer:
>   JCA interfaces are (a bit) outdated. If you are looking for a modern
>   CA Java interface check this out:
>     https://github.com/channelaccess/ca
Hi, Miroslav.
Is ca the successor to JCAE:
  https://github.com/paulscherrerinstitute/jcae
Both are developed at PSI, no?
Are both used in production?  Are both supported?  What does the future
of JCAE look like?
One thing I note is that it appears that JCAE has a client *and* a
server implementation, while ca has just a client.  Is that right?
Are there plans to add a server implementation to ca?
Would JCAE still be a sound choice for a new project that needed a
client *and* a server implementation, or even a sound choice for a
project that needed just a server implementation?  Or would it be better
to avoid it because it's being phased out, instead going with ca for the
client and CAJ (even though dated) for the server?
Thanks!
Lewis
Java API JCA / CAJ DBR_LONG Ryan Slominski
Re: Java API JCA / CAJ DBR_LONG Miroslav Pavleski
Prev: Re: Java API JCA / CAJ DBR_LONG Miroslav Pavleski
Next: CAJ and JCA links on website point to SourceForge J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Java API JCA / CAJ DBR_LONG matej . sekoranja
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
