1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Java API JCA / CAJ DBR_LONG
To: [email protected]
Date: Wed, 31 Jan 2018 09:08:53 +0100
Is ca the successor to JCAE:
  https://github.com/paulscherrerinstitute/jcae
Both are developed at PSI, no?
Are both used in production?  Are both supported?  What does the future
of JCAE look like?
I do not know JCAE. Quickly looking at the code it is a wrapper around JCA.
I was funded by PSI to write “ca”. I reused stable CAJ core but ditched old JCA interfaces
and replaced them with modern Java 8 interfaces. Afterwards PSI took over and added more
features.
One thing I note is that it appears that JCAE has a client *and* a
server implementation, while ca has just a client.  Is that right?
Right.
Are there plans to add a server implementation to ca?
I do not know.
However, CAJ server side interfaces are more modern than JCA
(but CAJS still use JCA DBR classes instead of generics).
Would JCAE still be a sound choice for a new project that needed a
client *and* a server implementation, or even a sound choice for a
project that needed just a server implementation?  Or would it be better
to avoid it because it's being phased out, instead going with ca for the
client and CAJ (even though dated) for the server?
I would go with ca client + CAJ server.
Cheers,
Matej
Re: Java API JCA / CAJ DBR_LONG Ebner Simon Gregor (PSI)
Prev: Fwd: JSPS Postdoctral Fellowships for Research in Japan Noboru Yamamoto
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Java API JCA / CAJ DBR_LONG J. Lewis Muir
Next: Re: Java API JCA / CAJ DBR_LONG Ebner Simon Gregor (PSI)
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
