1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Using EPICS PV Gateway with multiple IOCs on the same server
Date: Tue, 30 Jan 2018 09:06:53 +0000
Hi
We installed the CA gateway on a server with only EPICS_CA_ADDR_LIST configured in the .bashrc , this server is on a VLAN that can see the machine and beamline network. We have on the beamline network a server that has multiple IOCs running. This server's IP is used in the EPICS_CA_ADDR_LIST on the gateway server, but we can't see the beamline PVs, so I turned off all IOCs and ran one IOCs and it works fine. Seems the problem is due to the dynamically assigned UDP port because of multiple IOCs.
I figured out that it is possible to specify the port each IOC uses with EPICS_CAS_SERVER_PORT variable on the IOC server, the question is, is it possible for the CA gateway to see all these custom configured ports? IP routing maybe through the OS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Using EPICS PV Gateway with multiple IOCs on the same server Martin L. Smith
Prev: Re: CAJ and JCA links on website point to SourceForge Ralph Lange
Next: Re: Job openings at ITER Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CAJ and JCA links on website point to SourceForge Andrew Johnson
Next: Re: Using EPICS PV Gateway with multiple IOCs on the same server Martin L. Smith
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
