Hi Abdalla,
Have you looked at the following wiki page:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
I think that this will help you.
Marty
On 01/30/2018 03:06 AM, Abdalla Ahmad wrote:
Hi
We installed the CA gateway on a server with only EPICS_CA_ADDR_LIST configured
in the .bashrc , this server is on a VLAN that can see the machine and beamline
network. We have on the beamline network a server that has multiple IOCs
running. This server's IP is used in the EPICS_CA_ADDR_LIST on the gateway
server, but we can't see the beamline PVs, so I turned off all IOCs and ran one
IOCs and it works fine. Seems the problem is due to the dynamically assigned UDP
port because of multiple IOCs.
I figured out that it is possible to specify the port each IOC uses with
EPICS_CAS_SERVER_PORT variable on the IOC server, the question is, is it
possible for the CA gateway to see all these custom configured ports? IP routing
maybe through the OS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
- RE: Using EPICS PV Gateway with multiple IOCs on the same server Abdalla Ahmad
- Using EPICS PV Gateway with multiple IOCs on the same server Abdalla Ahmad
Re: Job openings at ITER Ralph Lange
<2018>
2025
2026
<2018>
2025
2026
