1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Suggest EPICS Base series type definitions on website
To: <[email protected]>
Date: Wed, 31 Jan 2018 11:50:24 -0600
Hi Lewis,
On 01/31/2018 10:25 AM, J. Lewis Muir wrote:
> I really appreciate the blurb that was added to explain the version
> numbering system and how to know if something is considered suitable
> for production use.  However, now I'm wishing for a similar blurb
> about the different release series types.  For example, there's
> 3.14.12.7, 3.15.5, and 3.16.1.  According to the version numbering
> system, all of those are suitable for production use.  I'm wishing
> for a blurb that can help me know which series I should choose. Ralph
> Lange gave a good start to this in:
> https://epics.anl.gov/tech-talk/2016/msg01398.php
> except now 3.14.x is labeled "maintenance," and that hasn't been
> defined.  And of course there's also now the EPICS 7.0 series labeled
> "new major release" for which I also don't know the definition.
I just added this wording to the base/index page, which may help clarify
things a little:
> What do the descriptive terms next to the above series mean? Most of
> them don't have any formal definition, they're just to give an
> indication whether we're still developing new features for them
> and/or applying bug-fixes. Here's the main point: The core epics
> developers work for organizations that still use (or are under
> contract to maintain) those release series which are not marked as
> "closed". New features are normally developed for and added to the
> latest release series only (although that partly depends on who is
> writing the code), but bug-fixes and updated operating system
> support get applied to the earliest series that make sense.
> Note that we make no explicit promises about continued future
> maintenance. When the APS Accelerator eventually stops using the
> 3.14 series that too will probably be closed (unless someone else
> funds continuing maintenance of it). A similar rule applies to
> operating system support — if you are the only site using an OS or an
> older OS version you will have to step up to keep newer releases of
> Base running on it. This is all a question of funding, we can only
> work on what our employers are willing to pay for.
> So which of the above series should you pick for a project? That
> choice depends on many things. If you need to use features that are
> only available in the latest release series then the choice is clear,
> but if not and you are fairly new to EPICS it might be better to
> avoid the newest series because tutorials and/or support software
> such as Asyn or other driver/device support might not have been
> updated yet to build on that series. In general though we suggest
> using the newest series that you can since it will be maintained for
> longer.
HTH,
- Andrew
Re: Suggest EPICS Base series type definitions on website J. Lewis Muir
Prev: Re: Java API JCA / CAJ DBR_LONG Ryan Slominski
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Suggest EPICS Base series type definitions on website J. Lewis Muir
Next: Re: Suggest EPICS Base series type definitions on website J. Lewis Muir
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
