1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Suggest EPICS Base series type definitions on website
Cc: [email protected]
Date: Wed, 31 Jan 2018 13:34:32 -0600
On 01/31, Andrew Johnson wrote:
> I just added this wording to the base/index page, which may help clarify
> things a little:
Hi, Andrew!
Thanks!  That helps a lot!
> > Note that we make no explicit promises about continued future
> > maintenance. When the APS Accelerator eventually stops using the
> > 3.14 series that too will probably be closed (unless someone else
> > funds continuing maintenance of it).
I'm not asking you to change anything, but FYI, when you say, "When the
APS Accelerator eventually stops using the 3.14 series that too will
probably be closed," I have no idea when that is likely to happen.  I'm
sure you have a sense of that, but I don't know if that means two years,
five years, or ten years.  Of course, you may not want to share that for
a number of reasons, and I would certainly understand.  I know that's
not the focus of what you're trying to say in that paragraph, either;
you're just trying to say that there's no guarantee of support for the
3.14 series (or any series), and I understand that.  However, I'm just
noting that if it ever became possible to share when an open series
would likely be closed, that would be useful information too.
Thanks again!
Lewis
Re: Suggest EPICS Base series type definitions on website Andrew Johnson
Suggest EPICS Base series type definitions on website J. Lewis Muir
Prev: New releases of areaDetector drivers ADPilatus, ADAndor, ADPerkinElmer, ADLightField, ADPointGrey, ADSimDetector, ADProsilica Mark Rivers
Next: Re: Suggest EPICS Base series type definitions on website Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Suggest EPICS Base series type definitions on website Andrew Johnson
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
