1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer seem to skip states with EPICS 3.16.1
To: <[email protected]>
Date: Wed, 31 Jan 2018 17:41:04 -0600
Hi Simon,
On 01/31/2018 04:54 PM, Simon Reiter wrote:
> Ok, I am pretty sure, that these test will only run for my host
> system. I guess, I need to copy the files somehow to the powerpc. And
> get perl running. I will investigate in this tomorrow.
Ah, you're cross-compiling. Don't worry about trying to get Perl to run
on the PowerPC then, but there are test programs in the following three
directories which check various aspects of the software and the OS that
might be helpful in finding problems:
> src/libCom/test
> src/ioc/db/test
> src/std/rec/test
These programs can be run individually by hand and the output is
human-readable, e.g.:
> tux% cd src/ioc/db/test/O.linux-x86_64
> tux% ./dbStateTest
> 1..20
> ok  1 - Finding nonexisting state fails
> ok  2 - Create state 'red'
> ok  3 - Find 'red' returns correct id
> ok  4 - Create existing 'red' returns correct id
> ok  5 - Finding nonexisting state still fails
> ok  6 - Create state 'blue'
> ok  7 - Find 'blue' returns correct id
> ok  8 - Create existing 'blue' returns correct id
> ok  9 - Finding nonexisting state still fails
> ok 10 - Default 'red' state is 0
> ok 11 - Default 'blue' state is 0
> ok 12 - After setting, 'red' state is 1
> ok 13 - 'blue' state is 0
> ok 14 - After setting, 'blue' state is 1
> ok 15 - 'red' state is 1
> ok 16 - After clearing, 'blue' state is 0
> ok 17 - 'red' state is 1
> ok 18 - After clearing, 'red' state is 0
> ok 19 - 'red' state is 0
> ok 20 - Finding nonexisting state still fails
>     Results
>        Tests: 20
>       Passed:  20 = 100.00%
Some of the later test programs will look for files from their
individual O.<arch> directory, their parent directory, and possibly even
from the O.Common directory as well so if possible try to make the whole
build tree accessible on the target (mounting it using NFS or SMB might
be simpler than trying to work out what files to copy). Each test
program displays a summary at the end telling you how many tests, passes
& failures were run.
If doing the above seems like too much work, I want to see what happens
if you replace the internals of your SET_PV macro with a simple printf()
of the state values, because currently you are monitoring the state
machine at the end of a long pipeline:
  SNL CA client → RSRV → dbAccess → record → dbEvent → RSRV → CA client
Calling printf() inside the SNL program would bypass that pipeline and
should prove whether the Sequencer is actually skipping states. Once we
know the answer to that we can decide if we need to investigate further
to explain the results you are seeing by monitoring it over CA.
HTH,
- Andrew
Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Re: Sequencer seem to skip states with EPICS 3.16.1 Andrew Johnson
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Next: Re: Seq-2.2.5 compilation on windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
ANJ, 01 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
