1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Segmentation fault when setting motorStatusProblem_ to 1
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 1 Feb 2018 18:32:31 +0000
How exactly do i run the IOC from gdb? When the IOC is running ps -A shows two processes called st.cmd. I do gdp -p [PID] then make the IOC crash by typing dbpf {...}Mtr 1234, but I get the same result as when I type backtrace without crashing the IOC:
0  0x00007fd1d8545bbd in read () at ../sysdeps/unix/syscall-template.S:81
#1  0x00007fd1d7df2b7d in rl_getc ()
   from /lib/x86_64-linux-gnu/libreadline.so.6
#2  0x00007fd1d7df3447 in rl_read_key ()
#3  0x00007fd1d7ddcc4c in readline_internal_char ()
#4  0x00007fd1d7ddd3c5 in readline ()
#5  0x00007fd1d9071970 in epicsReadline ()
   from /usr/lib/x86_64-linux-gnu/libCom.so.3.14.12.3
#6  0x00007fd1d9062fdf in ?? ()
#7  0x0000000000404956 in main ()
Sent: Thursday, February 01, 2018 11:22 AM
To: Sobhani, Bayan; [email protected]
Ø  What is causing the segmentation fault to occur?
You need to obtain a stack trace when the fault occurs.  Are you running on Linux or Windows?  On Linux you can run your program under gdb and when it crashes type the gdb command “backtrace”.  On Windows you need to build for the –debug architecture and then you can use the Visual Studio debugger when it crashes.
From: [email protected] [mailto:[email protected]] On Behalf Of Sobhani, Bayan
Sent: Thursday, February 01, 2018 10:17 AM
To: [email protected]
Subject: Segmentation fault when setting motorStatusProblem_ to 1
Here is my polling function for the MCS2 driver I am developing:
asynStatus SmarActMCS2Axis::poll(bool* moving_p){
        int64_t val;
        comStatus_=getp(channel_,&val);
        if(comStatus_!=asynSuccess){
                *moving_p=false;
               asynPrint(c_p_->pasynUserSelf,ASYN_TRACE_ERROR,"Error reading axis, channel=%d, comstatus=%d!\n", channel_,comStatus_);
                //c_p_ is a pointer to the controller object
                //setIntegerParam(c_p_->motorStatusProblem_,1);
                setIntegerParam(c_p_->motorStatusCommsError_,1);
                callParamCallbacks();
                return asynError;
        val=val/1000;
        setDoubleParam(c_p_->motorEncoderPosition_,(double)val);
        setDoubleParam(c_p_->motorPosition_,(double)val);
        if(is_moving(channel_)==true){
                *moving_p=true;
        else{
                *moving_p=false;
        setIntegerParam(c_p_->motorStatusProblem_,0);
        setIntegerParam(c_p_->motorStatusCommsError_,0);
        setIntegerParam(c_p_->motorStatusMoving_,*moving_p);
        setIntegerParam(c_p_->motorStatusDone_, ! *moving_p);
        return asynSuccess;
Notice that “setIntegerParam(c_p_->motorStatusProblem_,1);” is commented out because when I uncomment it, it causes the IOC to have a segmentation fault when I attempt to move an axis that is not connected. Surprisingly, “setIntegerParam(c_p_->motorStatusCommsError_,1);” does not cause the IOC to have a segmentation fault, and as expected raises a COMM alarm when I attempt to move an axis that is not connected. motorStatusProblem and motorStatusCommsError are not referenced anywhere else inside my code. What is causing the segmentation fault to occur?
Alex
RE: Segmentation fault when setting motorStatusProblem_ to 1 Mark Rivers
Re: Segmentation fault when setting motorStatusProblem_ to 1 Kasemir, Kay
Segmentation fault when setting motorStatusProblem_ to 1 Sobhani, Bayan
Prev: RE: Segmentation fault when setting motorStatusProblem_ to 1 Mark Rivers
Next: RE: Segmentation fault when setting motorStatusProblem_ to 1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
