1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AreaDetector repository inconsistent
To: "'J. Lewis Muir'" <[email protected]>, Jörn Dreyer <[email protected]>
Date: Mon, 5 Feb 2018 18:49:55 +0000
Hi Lewis,
> Or maybe Git submodules should be avoided.  It seems to me that there
> are a number of headaches related to the use of submodules in EPICS Base
> that come up from time to time; now it has come up in areaDetector, and
> I suspect the headaches will continue simply because submodules add
> complexity.
> I think a Git repo containing all of EPICS Base and another
> one containing all of areaDetector would be much simpler to deal with.
> I'm not a fan of submodules in general.
I think you are mixing up 2 very separate issues:
1) Having multiple repositories for EPICS base or areaDetector
2) Using git submodules to link those repositories
In my opinion it would be a terrible idea to go back to having areaDetector be a single git repository, which is how it was before R2-0.  By having multiple repositories we can independently release the core code (ADCore), the supporting libraries (ADSupport), and each detector (ADPilatus, etc.).  This is essential to producing timely releases.
The use of git submodules in areaDetector is completely optional for the end-user.  They can simply checkout out each repository independently and manually arrange them in the following hierarchy
areaDetector
  ADCore
  ADSupport
  ADPilatus
  etc.
The use of "git clone --recursive" is not required.  It is just a convenience if people want to check out lots of modules at the same time.
In areaDetector only areaDetector repository and the ADCore repository are released synchronously, i.e. they have the same tags.  All other modules are released independently and have different tags.  So it really does not make sense to check out R3-2 at the top-level and expect it to update the submodules to some specific release (except ADCore).
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On
> Behalf Of J. Lewis Muir
> Sent: Monday, February 05, 2018 12:23 PM
> To: Jörn Dreyer <[email protected]>
> Cc: [email protected]
> Subject: Re: AreaDetector repository inconsistent
> On 02/05, Jörn Dreyer wrote:
> > if I remember correctly I have seen this problem sometime ago
> > already. Maybe someone should look into implementing a commit hook
> > that prevents such situations.
> complexity.  I think a Git repo containing all of EPICS Base and another
> Lewis
Re: AreaDetector repository inconsistent J. Lewis Muir
AreaDetector repository inconsistent Jörn Dreyer
Re: AreaDetector repository inconsistent Ralph Lange
Re: AreaDetector repository inconsistent Jörn Dreyer
Prev: Re: AreaDetector repository inconsistent Ralph Lange
Next: Re: TDK Lamda Genesys EPICS IOC Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: AreaDetector repository inconsistent J. Lewis Muir
ANJ, 05 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
