1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TDK Lamda Genesys EPICS IOC
To: <[email protected]>
Date: Tue, 6 Feb 2018 10:33:20 +0000
Hi Han,
I know Heinz has sent some information, but in case it helps, our asyn application is available here: https://github.com/ISISComputingGroup/EPICS-TDKLambdaGenesys
Our db file and st.cmds are available here: https://github.com/ISISComputingGroup/EPICS-ioc/tree/master/TDK_LAMBDA_GENESYS
Some of the settings/commands in the st.cmd are particular to our environment, but it is worth noting that this is an addressed system, and if running on a multidrop set up you will need to send addresses all the time, if you run as we do with point to point comms, then you can send the address just once at the beginning as we have in st-psu.cmd.
Kathryn
-----Original Message-----
Sent: 05 February 2018 15:52
To: Baker, Kathryn (STFC,RAL,ISIS) <[email protected]>; [email protected]
Subject: Re: TDK Lamda Genesys EPICS IOC
Hi Kathryn,
   Thank for your quickly reply!
   Yes, could you guide me where I can find more information on them?
   Best,
   Han
On 02/05/2018 04:39 PM, [email protected] wrote:
> Hi Han,
> We have one that we use with their 1U and 2U PSUs. It's an ASYN driver with appropriate protocol and db files basically, so it might be of use to you, and from a quick look at the manual it should work. There are a few oddities with them, at least there are running them on RS232 via Moxa serial to Ethernet convertors on Windows.
> If you want more information, please do get in touch, and I can point you towards more information.
> Regards,
> Kathryn
> From: [email protected] [mailto:[email protected]] On Behalf Of Jeong Han Lee
> Sent: 05 February 2018 15:21
> To: [email protected]
> Subject: TDK Lamda Genesys EPICS IOC
> Hi
>    Does anyone has the epics IOC for TDK Lamda Genesys GEN 5kW SERIES POWER SUPPLIES?
>    I still doesn't know the exact model of the power supplies, which stakeholder would like to use. However, it could be similar with other models in the production category.
>    Best,
>    Han
Re: TDK Lamda Genesys EPICS IOC Jeong Han Lee
RE: TDK Lamda Genesys EPICS IOC kathryn.baker
Prev: RE: FLIR Spinnaker SDK: Request for input ulrik.pedersen
Next: Re: FLIR Spinnaker SDK: Request for input Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: TDK Lamda Genesys EPICS IOC Jeong Han Lee
Next: Re: TDK Lamda Genesys EPICS IOC Jeong Han Lee
ANJ, 06 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
