just my small remark,
the libraries that you noted (libGenApi_gcc540_v3_0.so and
libGCBase_gcc540_v3_0.so) are from the ebus SDK of Pleora. So that points to a
genicam/GigEVision compatible camera. For cameras with ethernet there is a
chance that they work with the aravisGigE driver. Did you try to talk to the
camera using the arv-tool-0.4 from the aravisGigE/vendor/aravis-linux-x86_64/
bin directory?
If the camera is using USB, then you are stuck with the manufacturer SDK.
Otherwise, give it a try.
Jörn
Am Dienstag, 6. Februar 2018, 11:05:26 CET schrieb
[email protected]:
> Hi Mark,
> To my knowledge we don't have any Spinnaker cameras here at Diamond at the
> moment... However, we have been arguing about similar topics with detector
> vendors in the past and what seems to have worked is to ask that they build
> their Linux libraries against large-scale, long-term support Linux
> distributions - and follow their release cycle. These distributions are
> used across many sites and organisations across the world. The
> compiler/libs versions on there are fairly conservative and constant.
> In my view, currently RedHat (or CentOS) 7 would be a good, conservative
> choice that would be supported and in use for several years. If they insist
> on a debian-based distribution then go for one of the Ubuntu Long Term
> Support (LTS) ones.
> An even better and more portable solution would be to wrap their entire
> public API in "extern C". A C API is more portable across compiler/linker
> versions, but C++ is not (your error relates to a C++ string type).
> Obviously, this could potentially be a major change to their code and API!
> Just my £0.02 worth...
> Cheers,
> Ulrik
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Mark Rivers Sent: 05 February 2018 14:41
> To: 'EPICS Mailing list' <[email protected]>
> Subject: FLIR Spinnaker SDK: Request for input
> Folks,
> I have begun work on a new ADSpinnaker driver based on the Spinnaker SDK.
> The Spinnaker libraries for Windows are no problem. However, the Linux
> libraries have names like:
> The name implies that they were built with gcc 5.4.0. When I try to link
> against these libraries on my Centos 7 system with gcc 4.8.5 I get errors
> like the following:
> /home/epics/devel/areaDetector-3-2/ADSpinnaker/lib/linux-x86_64/libSpinnaker
> .so: undefined reference to `std::__cxx11::basic_string<char,
> std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned
> long) const@GLIBCXX_3.4.21'
> This means it requires GLIBCXX 3.4.21. When I run the following command
> "strings" on my Centos 7 system I see that I have the following versions of
> GLIBCXX:
> corvette:ADSpinnaker/spinnakerApp/src>strings /usr/lib/libstdc++.so.6 | grep
> LIBCXX GLIBCXX_3.4
> GLIBCXX_3.4.1
> GLIBCXX_3.4.2
> GLIBCXX_3.4.3
> GLIBCXX_3.4.4
> GLIBCXX_3.4.5
> GLIBCXX_3.4.6
> GLIBCXX_3.4.7
> GLIBCXX_3.4.8
> GLIBCXX_3.4.9
> GLIBCXX_3.4.10
> GLIBCXX_3.4.11
> GLIBCXX_3.4.12
> GLIBCXX_3.4.13
> GLIBCXX_3.4.14
> GLIBCXX_3.4.15
> GLIBCXX_3.4.16
> GLIBCXX_3.4.17
> GLIBCXX_3.4.18
> GLIBCXX_3.4.19
> GLIBCXX_DEBUG_MESSAGE_LENGTH
> So the most recent version I have is 3.4.19, I don't have 3.4.21.
> I think it is unfortunate that their Linux Spinnaker version requires a very
> recent version of Linux and gcc. I believe it will pose a problem for many
> of our sites that are using older versions of gcc.
> Assuming it is technically possible, I would like to try to convince FLIR to
> release a version of the library built with an older version of gcc. Other
> vendors (e.g. AVT) do this.
> In order to convince them I would like to get some input from sites that are
> currently using Point Grey/FLIR cameras or plan to do so within a year or
> so.
> - About how many of their cameras do you current use or plan on using within
> the next year? - What version of Linux, gcc, and GLIBCXX are you using on
> your production machines?
> Thanks,
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Wednesday, January 31, 2018 4:50 PM
> Subject: FLIR 10Gbit Ethernet camera question
> Folks,
> FLIR (formerly Point Grey) has introduced 10 Gbit Ethernet cameras. They
> currently sell a 4096 x 3000 pixel version which can do 68 frames/s for
> $3,950. They will soon start selling a 2448 x 2048 camera which can do 162
> frames/s (price not announced yet). These are very interesting cameras,
> since they use the Sony CMOS chips with very low read noise and global
> shutter. These data rates are 775-796 MB/s, which is more than 2x faster
> than the same chips using a USB-3 interface.
> These cameras cannot use the FlyCap2 SDK that other Point Grey cameras use.
> They require their new Spinnaker SDK. They are GeniCAM compliant, so they
> may also work with the aravisGigE driver. Note that their new BlackFlyS
> cameras also require the Spinnaker SDK, they don't work with FlyCap2
> either.
> My questions:
> - Has anyone begun an areaDetector driver that uses the Spinnaker
> SDK?
> - Does anyone know if these 10Gbit cameras will work with the
> aravisGigE driver? Any idea if aravisGigE is capable of running at the
> 10GBit Ethernet speeds?
> Thanks,
> Mark
- Re: FLIR Spinnaker SDK: Request for input Mark Rivers
- FLIR 10Gbit Ethernet camera question Mark Rivers
- FLIR Spinnaker SDK: Request for input Mark Rivers
- RE: FLIR Spinnaker SDK: Request for input ulrik.pedersen
RE: TDK Lamda Genesys EPICS IOC kathryn.baker
<2018>
2025
2026
<2018>
2025
2026
