1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux
To: "'Mooney, Tim M.'" <[email protected]>, "Johannes Spinneken (EGI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 6 Feb 2018 20:40:19 +0000
Hi Johannes,
Here is one quick measurement.
-          I have an areaDetector simDetector running on a Linux machine.  It has a small image size (50x50) so it can run very fast.  It is doing about 5,500 frames/s.
-          There is an image counter PV that updates each time there is a new image, i.e. at 5,500 Hz.
-          I ran “camonitor” on a different Linux machine to see how fast it received the monitor updates on that PV.  I used –tcs so we see both the CA client timestamps and the CA server timestamps. I sent the camonitor output to a file so the terminal I/O would not slow it down.
-          Both of these machines have 10GB Ethernet connections.
This is the result, covering a time period of about 10 ms.
Viper:~>camonitor -tcs 13SIM1:cam1:ArrayCounter_RBV > test.out
^C
Viper:~>more test.out
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.602116(2018-02-06 14:34:30.602287) 4182302
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.602320(2018-02-06 14:34:30.602489) 4182303
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.602505(2018-02-06 14:34:30.602611) 4182304
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.602696(2018-02-06 14:34:30.602888) 4182305
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.602899(2018-02-06 14:34:30.603005) 4182306
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.603127(2018-02-06 14:34:30.603238) 4182307
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.603344(2018-02-06 14:34:30.603470) 4182308
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.603536(2018-02-06 14:34:30.603642) 4182309
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.603727(2018-02-06 14:34:30.603838) 4182310
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.603899(2018-02-06 14:34:30.604019) 4182311
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.604109(2018-02-06 14:34:30.604228) 4182312
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.604318(2018-02-06 14:34:30.604440) 4182313
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.604506(2018-02-06 14:34:30.604606) 4182314
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.604692(2018-02-06 14:34:30.604842) 4182315
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.604884(2018-02-06 14:34:30.605005) 4182316
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605076(2018-02-06 14:34:30.605206) 4182317
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605260(2018-02-06 14:34:30.605363) 4182318
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605427(2018-02-06 14:34:30.605539) 4182319
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605613(2018-02-06 14:34:30.605725) 4182320
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605795(2018-02-06 14:34:30.605919) 4182321
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.605966(2018-02-06 14:34:30.606132) 4182322
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.606149(2018-02-06 14:34:30.606265) 4182323
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.606319(2018-02-06 14:34:30.606431) 4182324
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.606479(2018-02-06 14:34:30.606594) 4182325
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.606611(2018-02-06 14:34:30.606727) 4182326
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.606820(2018-02-06 14:34:30.606917) 4182327
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607015(2018-02-06 14:34:30.607116) 4182328
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607186(2018-02-06 14:34:30.607287) 4182329
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607363(2018-02-06 14:34:30.607459) 4182330
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607542(2018-02-06 14:34:30.607643) 4182331
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607732(2018-02-06 14:34:30.607841) 4182332
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.607914(2018-02-06 14:34:30.608016) 4182333
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608100(2018-02-06 14:34:30.608202) 4182334
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608252(2018-02-06 14:34:30.608355) 4182335
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608432(2018-02-06 14:34:30.608532) 4182336
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608620(2018-02-06 14:34:30.608731) 4182337
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608801(2018-02-06 14:34:30.608909) 4182338
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.608983(2018-02-06 14:34:30.609098) 4182339
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.609164(2018-02-06 14:34:30.609279) 4182340
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.609341(2018-02-06 14:34:30.609449) 4182341
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.609526(2018-02-06 14:34:30.609625) 4182342
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.609701(2018-02-06 14:34:30.609817) 4182343
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.609877(2018-02-06 14:34:30.609990) 4182344
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610057(2018-02-06 14:34:30.610185) 4182345
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610268(2018-02-06 14:34:30.610392) 4182346
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610454(2018-02-06 14:34:30.610568) 4182347
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610620(2018-02-06 14:34:30.610739) 4182348
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610800(2018-02-06 14:34:30.610908) 4182349
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.610988(2018-02-06 14:34:30.611097) 4182350
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.611168(2018-02-06 14:34:30.611289) 4182351
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.611355(2018-02-06 14:34:30.611454) 4182352
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.611536(2018-02-06 14:34:30.611644) 4182353
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.611728(2018-02-06 14:34:30.611834) 4182354
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.611915(2018-02-06 14:34:30.612013) 4182355
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.612084(2018-02-06 14:34:30.612204) 4182356
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.612265(2018-02-06 14:34:30.612388) 4182357
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.612447(2018-02-06 14:34:30.612543) 4182358
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.612619(2018-02-06 14:34:30.612721) 4182359
13SIM1:cam1:ArrayCounter_RBV   2018-02-06 14:34:30.612806(2018-02-06 14:34:30.612915) 4182360
You can see that it does not appear to lose any monitors, and the time between monitors is just under 200 microseconds.  So at least in this setup we have not yet hit the EPICS protocol or network speed limits.
From: [email protected] [mailto:[email protected]] On Behalf Of Mooney, Tim M.
Sent: Tuesday, February 06, 2018 2:12 PM
To: Johannes Spinneken (EGI) <[email protected]>; [email protected]
Subject: Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux
Hi Johannes,
With an interrupt service routine, vxWorks can read from or write to an IndustryPack FPGA at around 10 kHz, but I would not try to process an EPICS record at that rate - at least not a record that isn't prepared to throttle the rate at which it posts monitors.  I don't usually process general purpose EPICS records faster than around 100 Hz.  I think it's pretty common practice to keep stuff faster than around 100 Hz restricted to driver code, which doesn't really have to know about EPICS.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Johannes Spinneken (EGI) <[email protected]>
Sent: Tuesday, February 6, 2018 1:33:13 PM
To: [email protected]
Subject: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux
Hi
I am fairly new to EPICS and have been testing an application with the following setup:
  • National Instruments cRIO running an EPICS server
  • EPICS client on RT Linux (fully preemptible Kernel 4.9.76) using EPICS base libs (C application)
  • PV write on cRIO in LabVIEW RT, with new data at 1ms intervals (using 1ms timed loop)
  • Read of EPICS PV in RT Linux with loop times <1ms
  • Posting data back to another EPICS PV to then be read as “round trip” timing on cRIO
The setup works in principle, but I am seeing higher latencies than I was expecting. I was hoping to achieve latencies in the low ms order (say 1 – 2ms data round trip from cRIO to RT Linux back to cRIO). In practice, I observe round-trip timings of order 10ms. Two questions:
(i)                   What is the best timing (latency) that can generally be achieved using EPICS? Is there something fundamental in the protocol that prohibits data exchange in the low ms order? I understand that this will of course depend on target hardware / software, but a ballpark figure would be good as “expectation management”. A typical ping between cRIO and Linux RT takes approx. 0.2ms, so the hardware seems clearly capable of <1ms timings.
(ii)                 Does anyone have experience with running EPICS on LabVIEW RT / cRIO? I suspect some (most) of the latency is due to the way in which NI handles TCP traffic. I already discovered that data is normally buffered for 10ms (or 8 kB). This can be avoided by using the Shared Variable Data Flush VI:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvcomm/flushsharedvar/
which indeed reduced round-trip timings by around 8-10ms. However, I seem to be unable to push timings down further below the 10ms round-trip mark. Any guidance would be much appreciated.
Many thanks!
Best wishes
Johannes
Johannes Spinneken PhD FRSA
Principal Systems Engineer
Evergreen Innovations UK & USA
+1 916 266 3709 (US cell)
+44 7868 923583 (UK mobile)
www.evergreeninnovations.co
RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mark Rivers
Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Johannes Spinneken (EGI)
Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mooney, Tim M.
Prev: Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mooney, Tim M.
Next: Re: EtherCAT newbie question Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mark Rivers
ANJ, 09 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
