1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer seem to skip states with EPICS 3.16.1
To: "Hartman, Steven M." <[email protected]>, Simon Reiter <[email protected]>
Date: Thu, 8 Feb 2018 15:26:32 +0100
On 02/08/2018 12:00 AM, Hartman, Steven M. wrote:
>> On Feb 7, 2018, at 5:31 PM, Simon Reiter <[email protected]> wrote:
>>>  state check {
>>>    when(pv_mem < 2) {
>>>    } state check_valid
>>>    when(pv_rate != 0) {
>>>    } state check
>>>    when(pv_rate == 0 && delay(Waittime)) {
>>>    } state check_failed
> I would avoid the
>    } state check
> in the check state as that will just loop, burning CPU. Try something like this . . .
>  state check {
>    when(pv_mem < 2) {
>    } state check_valid
>    when(pv_rate == 0 {
>    } state check_delay
>  state check_delay {
>    } state check
>    when (pv_rate == 0 && delay(Waittime)) {
Yes, exactly. The original program with the busy loop can prevent any
threads with lower or equal priority (such as CA event threads) from
executing. This may work in some circumstances, depending on the details
of how the scheduler is configured but is not something I would rely on.
Steven's alternative with two states works reliably and does not depend
on how the scheduler works.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Re: Sequencer seem to skip states with EPICS 3.16.1 Andrew Johnson
Re: Sequencer seem to skip states with EPICS 3.16.1 Hartman, Steven M.
Prev: Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Next: RE: Data format using NDFileHDF5 ulrik.pedersen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Hartman, Steven M.
Next: Fwd: JSPS Postdoctral Fellowships for Research in Japan Noboru Yamamoto
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
