1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why is post_event deprecated?
To: Dirk Zimoch <[email protected]>, [email protected]
Date: Thu, 8 Feb 2018 07:45:31 -0800
On 02/08/2018 12:45 AM, Dirk Zimoch wrote:
Hi Tim
Isn't that what "deprecated" means: supported but discouraged?
I thought it also indicates that support will go away (which would make
maintaining applications that need to be built against newer as well
as older versions of epics a pain).
A side-effect are many compiler warnings that could obscure more
serious issues.
Dirk
On 07.02.2018 00:43, Till Straumann wrote:
I'm using some (old) code with 3.15.5 and learned that
post_event() had been deprecated in favour of postEvent().
While I have no real problems with the new flavour which
in some cases might be really nice - I do question the
decision to deprecate post_event() (rather than, let's say
discourage its use for new applications but continue to
support it).
1.) There are probably many existing applications out there
     using post_event(). People have better things to do than
     migrating to the new version.
2.) The backwards-compatibility solution currently in place
     is cheap.
3.) People might have to use code with both, 3.15+ as well
     as older versions. It is a pain to have to maintain
     #ifdefs for this.
My two cents...
Best
- Till
Re: Why is post_event deprecated? Andrew Johnson
Re: Why is post_event deprecated? Dirk Zimoch
Why is post_event deprecated? Till Straumann
Prev: RE: Data format using NDFileHDF5 ulrik.pedersen
Next: Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Why is post_event deprecated? Dirk Zimoch
Next: Re: Why is post_event deprecated? Andrew Johnson
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
