1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: Dirk Zimoch <[email protected]>, [email protected]
Date: Thu, 8 Feb 2018 17:30:55 +0100
Even when I solved the issue different, I appreciate that you keep working on this.
Simon
On 02/08/2018 02:23 PM, Dirk Zimoch wrote:
Attached is a patch file for dbScan.c which should fix the problem and restore backward compatibility.
I have created (and quickly tested) it with EPICS 7 but I guess it should work with 3.16 as well.
The hack is to treat "x.000000" and "x" as the same event name if x is an integer between 0 and 255. ("0" and "0.000000" are no event at all now just like "").
I will create a merge request for the EPICS base repo once I have proper tests and documentation.
Dirk
On 08.02.2018 10:08, Dirk Zimoch wrote:
This is interesting. When I wrote the "named Events" feature some years ago, I tested with something like 2 which became "2" and all was fine. However I never thought about generating the value from a calc. This should be fixed, or at least "2.000000" and "2" should be treated as equal.
I will start working on it...
Dirk
On 30.01.2018 17:20, Simon Reiter wrote:
Thanks so far.
postEvent 2
works fine.
Up to now, my event record has an INP field, which links to a calc record.
This calc record only provides the correct value under some conditions.
How can I do this without using a state machine?
record(calc,"$(BOARDNAME):ErrorFlags:calc")
   field(INPA, "$(BOARDNAME):InitDone:S CPP")
   field(CALC, "A ? 2 : 0")
record(event, "$(BOARDNAME):ErrorFlags:trg")
   field(INP,  "$(BOARDNAME):ErrorFlags:calc CPP")
This is my current code. The value of event is now 2.000000 in the correct case.
Simon Reiter
II. Physikalisches Institut
Justus-Liebig-Universtität
Heinrich-Buff-Ring 16
D-35392 Giessen
Tel: +49 641 99 33250
Scanning on event number fails with EPICS 3.16 Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Prev: Re: Why is post_event deprecated? Till Straumann
Next: Re: Why is post_event deprecated? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Next: Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
