This is interesting. When I wrote the "named Events" feature some years
ago, I tested with something like 2 which became "2" and all was fine.
However I never thought about generating the value from a calc. This
should be fixed, or at least "2.000000" and "2" should be treated as equal.
I will start working on it...
Dirk
On 30.01.2018 17:20, Simon Reiter wrote:
Thanks so far.
postEvent 2
works fine.
Up to now, my event record has an INP field, which links to a calc record.
This calc record only provides the correct value under some conditions.
How can I do this without using a state machine?
record(calc,"$(BOARDNAME):ErrorFlags:calc")
field(INPA, "$(BOARDNAME):InitDone:S CPP")
field(CALC, "A ? 2 : 0")
record(event, "$(BOARDNAME):ErrorFlags:trg")
field(INP, "$(BOARDNAME):ErrorFlags:calc CPP")
This is my current code. The value of event is now 2.000000 in the
correct case.
- Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
- Scanning on event number fails with EPICS 3.16 Simon Reiter
- Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
- Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Re: procServ under systemd service Ralph Lange
Data format using NDFileHDF5 steve.kinder
<2018>
2025
2026
<2018>
2025
2026
