1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Data format using NDFileHDF5
To: <[email protected]>
Date: Thu, 8 Feb 2018 09:15:14 +0000
I am using the NDFileHDF5 areaDetector plugin to write data and attributes collected from PCO cameras. I've been able to store data and attributes using XML files to define the attributes of interest and the following for the HDF5 layout:
<entry>
  <group name="Data" ndattr_default="true">
    <dataset name="Images" source="detector" det_default="true"></dataset>
  </group>
</entry>
My end user sees this as a 3D data array with separate attributes which seemed fine. They would however like what I think is a list of separate 2D arrays with the attributes directly connected to each array they are relevant to. I've spent some time trying to figure out how to do that via the XML layout file but not got there yet. I will continue but I am beginning to wonder whether I will have to modifiy the plugin source.
In the meantime I wondered whether anyone had an example XML layout file that might help me get the desired structure? Or advice on whether the plugin will need modifying?
Thanks
Steve
Re: Data format using NDFileHDF5 Mark Rivers
Prev: Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Next: Re: procServ under systemd service Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mca compilation fails on windows 7, keyword re-definition Gofron, Kazimierz
Next: Re: Data format using NDFileHDF5 Mark Rivers
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
