1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scanning on event number fails with EPICS 3.16
To: EPICS Tech Talk <[email protected]>
Date: Tue, 30 Jan 2018 15:59:15 +0100
According to the release notes,
3.15.0 changed the EVNT to be a name instead of a number.
    postEvent name
or (on VxWorks)
    postEvent(eventNameToHandle("name"))
can be used from the iocShell to manually generate the event.
Cheers,
~Ralph
On Tue, Jan 30, 2018 at 3:13 PM, Simon Reiter <[email protected]> wrote:
Dear all,
while updating our IOC from EPICS 3.14.12.6 to 3.16.1 I discovered a problem with the event record.
I use several binary output records, which listen to event number 2. If the corresponding event record is processed, the binary output records do no process. If I force them to with "dbpf <PV-NAME>.PROC 0", it works.
The IOC is running on a PowerPC.
I use
  field(SCAN, "Event")
  field(EVNT, "2")
in the bo record.
Have there been changes in the event record or shall I use a different way to trigger these output PVs?
Best regards,
Simon
Simon Reiter
II. Physikalisches Institut
Justus-Liebig-Universtität
Heinrich-Buff-Ring 16
D-35392 Giessen
Tel: +49 641 99 33250
Scanning on event number fails with EPICS 3.16 Simon Reiter
Prev: Re: Scanning on event number fails with EPICS 3.16 Benjamin Franksen
Next: Re: pvPut error message by Sequencer Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scanning on event number fails with EPICS 3.16 Simon Reiter
Next: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
