On 01/30/2018 03:31 PM, Simon Reiter wrote:
> after updating from EPICS 3.14.12.6 to 3.16.1 I receive the following
> message.
> A PV is set by the sequencer (2.2.4). It is actually done, but every
> time, the sequencer set the PV, I get this message.
> sevr=minor ca_array_put(typeToCA(type), count, var->chid, value):
> Channel write request failed
> int pv_variable;
> assign pv_variable to "{IOC}:timeout:S";
> pv_variable = value;
> pvPut(pv_variable);
> The connected PV is binary output.
From looking at the CA sources it seems that this is ECA_PUTFAIL error
code, which is used as the default (catch-all) error code in
src/ca/client/oldChannelNotify.cpp e.g. line 525:
catch ( ... )
caStatus = ECA_PUTFAIL;
So we know that /something/ fails and it is not any of the expected
exceptions (cacChannel::badString, ... std::bad_alloc). You could insert
debug statements in the catch-all clause to print more information about
the exception.
Does a caput from the command line work also result in an error message?
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Re: pvPut error message by Sequencer Ralph Lange
- Re: pvPut error message by Sequencer Simon Reiter
- Scanning on event number fails with EPICS 3.16 Simon Reiter
- pvPut error message by Sequencer Simon Reiter
Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
<2018>
2025
2026
<2018>
2025
2026
