1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FLNK length limit
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 09 Feb 2018 16:33:13 +0000
On Fri, 9 Feb 2018 at 14:43, Kasemir, Kay <[email protected]> wrote:
> Is the FLNK limited to 40 chars?
No.
What's limited to 40 chars would be TheNewLinkValue if you write it like this, which sends the value as a it as a DBF_STRING:
   caput record.FLNK "TheNewLinkValue"
This what I was doing, yes.
But you can write it as a byte waveform by using record.FLNK$ as a channel name.
Will give it a try !
The only limitation should be related to the record name based on
dbDefs.h:#define PVNAME_STRINGSZ 61
-Kay
Hinko
.. the more I see the less I believe.., AE AoR
FLNK length limit Hinko Kocevar
Re: FLNK length limit Kasemir, Kay
Prev: Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Gabriel de Souza Fedel
Next: Re: FLNK length limit J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: FLNK length limit Kasemir, Kay
ANJ, 09 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
