> Is the FLNK limited to 40 chars?
No.
What's limited to 40 chars would be TheNewLinkValue if you write it like this, which sends the value as a it as a DBF_STRING:
caput record.FLNK "TheNewLinkValue"
But you can write it as a byte waveform by using record.FLNK$ as a channel name.
The only limitation should be related to the record name based on
dbDefs.h:#define PVNAME_STRINGSZ 61
-Kay
- Re: FLNK length limit Hinko Kocevar
- Re: FLNK length limit J. Lewis Muir
- FLNK length limit Hinko Kocevar
Question about values of historic PVs dislpayed in CSS XY Graph widget lzf neu
回复: Question about values of historic PVs dislpayed in CSS XY Graph widget lzf neu
<2018>
2025
2026
<2018>
2025
2026
