1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: P4P release 1.0 (PVAccess for Python)
From: "Williams Jr., Ernest L." <[email protected]>
To: Michael Davidsaver <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Mon, 12 Feb 2018 01:47:36 +0000
Hi Michael,
Awesome news.  Thanks for releasing this.
My initial results are below.
I look forward to continued tests
From: [email protected] <[email protected]> on behalf of Michael Davidsaver <[email protected]>
Sent: Sunday, February 11, 2018 2:59 PM
To: EPICS Tech-Talk
Subject: P4P release 1.0 (PVAccess for Python)
The first release of the P4P (PVAccess for Python) module is available
P4P is a binding for the PVAccess protocol client, and part of the server APIs.
The client get, put, rpc, and monitor operations are supported.  As a server,
only the rpc operation can be implemented.
Download
https://github.com/mdavidsaver/p4p/releases/download/1.0/p4p-1.0.tar.gz
Building from source
https://mdavidsaver.github.io/p4p/building.html
<============ Building ================>==================================>
The build was successful.
Host OS == Fedora release 27 (Twenty Seven)
Kernel == 4.14.16-300.fc27.x86_64
GCC == gcc version 7.3.1 20180130 (Red Hat 7.3.1-2) (GCC)
EPICS_BASE = R7.0.1.1
PYTHON = Python 3.6.4
numpy =  numpy==1.14.0
===> Running unittests =======================================================<
Some results when building from source on Fedora 26:
make nose does not succeed: (maybe because I am using python3?)
[ernesto@localhost p4p-1.0]$ make nose
make -C ./configure install
make[1]: Entering directory '/usr/local/controls/package/p4p-1.0/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
   T_A=linux-x86_64 install
make[2]: Entering directory '/usr/local/controls/package/p4p-1.0/configure/O.linux-x86_64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/usr/local/controls/package/p4p-1.0/configure/O.linux-x86_64'
make[1]: Leaving directory '/usr/local/controls/package/p4p-1.0/configure'
make -C ./src install
make[1]: Entering directory '/usr/local/controls/package/p4p-1.0/src'
make[2]: Entering directory '/usr/local/controls/package/p4p-1.0/src/O.linux-x86_64'
make[2]: Leaving directory '/usr/local/controls/package/p4p-1.0/src/O.linux-x86_64'
make[1]: Leaving directory '/usr/local/controls/package/p4p-1.0/src'
make -C src/O.linux-x86_64 nose
make[1]: Entering directory '/usr/local/controls/package/p4p-1.0/src/O.linux-x86_64'
make -f ../Makefile TOP=../.. T_A=linux-x86_64  nose
PYTHONPATH="/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64" python -m nose -P p4p
E
ERROR: Failure: ImportError (/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64/p4p/_p4p.so: undefined symbol: _Py_FalseStruct
Traceback (most recent call last):
 File "/usr/lib/python2.7/site-packages/nose/loader.py", line 407, in loadTestsFromName
   module = resolve_name(addr.module)
 File "/usr/lib/python2.7/site-packages/nose/util.py", line 312, in resolve_name
   module = __import__('.'.join(parts_copy))
 File "/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64/p4p/__init__.py", line 2, in <module>
   from .wrapper import Value, Type
 File "/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64/p4p/wrapper.py", line 2, in <module>
   from ._p4p import Type, Value
ImportError: /usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64/p4p/_p4p.so: undefined symbol: _Py_FalseStruct
Ran 1 test in 0.001s
FAILED (errors=1)
make[2]: *** [../Makefile:55: nose] Error 1
make[1]: *** [Makefile:8: nose] Error 2
make[1]: Leaving directory '/usr/local/controls/package/p4p-1.0/src/O.linux-x86_64'
make: *** [Makefile:17: nose] Error 2
However, the other recommended option does run and complete with success
[ernesto@localhost linux-x86_64]$ cd /usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64
[ernesto@localhost linux-x86_64]$ PYTHONPATH=/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64 nosetests-3
..........................2018-02-11T17:34:47.253 Using dynamically assigned TCP port 35359.
.2018-02-11T17:34:47.284 Using dynamically assigned TCP port 36373.
.....2018-02-11T17:34:47.402 Using dynamically assigned TCP port 48073.
Ran 57 tests in 1.084s
OK
Initial tests with command line tools look good as well:
[ernesto@localhost linux-x86_64]$ PYTHONPATH=/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64 python3 -m p4p.client.cli get
ernesto:aiExample1
ernesto:aiExample1 Sun Feb 11 17:36:51 2018 9.0
[ernesto@localhost linux-x86_64]$ PYTHONPATH=/usr/local/controls/package/p4p-1.0/python3.6m/linux-x86_64 python3 -m p4p.client.cli moni
tor ernesto:aiExample1
ernesto:aiExample1 Sun Feb 11 17:37:09 2018 7.0
ernesto:aiExample1 Sun Feb 11 17:37:10 2018 8.0
ernesto:aiExample1 Sun Feb 11 17:37:11 2018 9.0
ernesto:aiExample1 Sun Feb 11 17:37:12 2018 0.0
ernesto:aiExample1 Sun Feb 11 17:37:13 2018 1.0
ernesto:aiExample1 Sun Feb 11 17:37:14 2018 2.0
ernesto:aiExample1 Sun Feb 11 17:37:15 2018 3.0
ernesto:aiExample1 Sun Feb 11 17:37:16 2018 4.0
ernesto:aiExample1 Sun Feb 11 17:37:17 2018 5.0
ernesto:aiExample1 Sun Feb 11 17:37:18 2018 6.0
ernesto:aiExample1 Sun Feb 11 17:37:19 2018 7.0
^C[ernesto@localhost linux-x86_64]$
Getting started with the client API
https://mdavidsaver.github.io/p4p/starting.html
Writing an RPC server (and client)
https://mdavidsaver.github.io/p4p/rpc.html
documentation index
Re: P4P release 1.0 (PVAccess for Python) Michael Davidsaver
Prev: P4P release 1.0 (PVAccess for Python) Michael Davidsaver
Next: Re: P4P release 1.0 (PVAccess for Python) Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 11 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
