1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PMAC asyn autoconnect issue
To: Torsten Bögershausen <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Feb 2018 10:44:20 -0500
Hi Torsten,
Just for the sake of completeness I rebuilt my whole environment from source (git):
Base R3.15.5
Motor R6-10
Asyn R4-33
pmacasyn from here (with all patches in debian/patches applied):
https://github.com/epicsdeb/pmacasyn
Here's a minimal IOC that reproduces the issue
$ cat st.cmd
#!../../bin/linux-x86_64/tpmac
< envPaths
epicsEnvSet("STREAM_PROTOCOL_PATH","${PMACUTIL}/pmacUtilApp/protocol")
epicsEnvSet("PREFIX","LABTEST:STPC01")
dbLoadDatabase("${TOP}/dbd/tpmac.dbd",0,0)
tpmac_registerRecordDeviceDriver(pdbbase)
pmacAsynIPConfigure("P0","<ip redacted>:1025")
#asynSetOption("P0",0,"disconnectOnReadTimeout","Y")
pmacCreateController("motor","P0",0,2,100,1000)
pmacCreateAxis("motor", 1)
pmacCreateAxis("motor", 2)
dbLoadTemplate("$(TOP)/db/labTest.substitutions")
iocInit()
$ cat labTest.substitutions
file "$(TOP)/db/motor.db"
# ADDR ---> axis #
# NOTE ---> 2 asyn ports: 1) lowel comms ("P0"), and 2) Motor Record ("motor")
pattern
{ P,             M,                   MOTOR,   PORT,    ADDR, DESC,             DTYP,        EGU,    MRES,PREC     }
{ "LABTEST:", "STPC01:M1",           "motor", "P0",    1,      "Axis 1",         asynMotor,    "mm",    0.00079375,    2     }
{ "LABTEST:", "STPC01:M2",            "motor", "P0",    2,      "Axis 2",         asynMotor,    "mm",    0.00079375,    2    }
$ cat db/motor.db
record(motor,"$(P)$(M)")
    field(DESC,"$(DESC)")
    field(DTYP,"$(DTYP)")
    field(OUT,"@asyn($(MOTOR),$(ADDR))")
    field(RTRY,"0")
  # Use of MRES is deliberate on the following line.
  # This sets the retry deadband to the smallest possible size.
  field(RDBD,$(MRES="1"))
  field(MRES,$(MRES="1"))
  field(EGU,$(EGU="None"))
  field(PREC,$(PREC="0"))
epics> dbl
LABTEST:STPC01:M1
LABTEST:STPC01:M2
As soon as I turn off the controller, these messages appear:
epics> 2018/02/15 10:12:19.085 P0 read pmacFlush failed - thisRead=0, eomReason=0, status=1
2018/02/15 10:12:29.095 P0 read pmacReadReady failed status=1,retval=02018/02/15 10:12:29.095 pmacController::lowLevelWriteRead: Error from pasynOctetSyncIO->writeRead. command: ???
2018/02/15 10:12:29.095 pmacController::getGlobalStatus: Error reading ???.
2018/02/15 10:12:29.095 pmacController::poll: Error reading or setting params.
2018/02/15 10:12:29.095 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#1 ? F P
Response:2018/02/15 10:12:29.095 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#2 ? F P
Response:2018/02/15 10:12:30.096 pmacController::getGlobalStatus: Error reading ???. nvals: -1, response:
2018/02/15 10:12:30.096 pmacController::poll: Error reading or setting params.
2018/02/15 10:12:30.096 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#1 ? F P
Response:2018/02/15 10:12:30.096 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#2 ? F P
Response:2018/02/15 10:12:31.096 pmacController::getGlobalStatus: Error reading ???. nvals: -1, response:
2018/02/15 10:12:31.096 pmacController::poll: Error reading or setting params.
2018/02/15 10:12:31.096 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#1 ? F P
Response:2018/02/15 10:12:31.096 drvPmacAxisGetStatus: not all status values returned. Status: 0
Command :#2 ? F P
Response:
After 20 min (see below), I powered the controller back on, but the messages continued.
As Mark mentioned, it seems that Linux takes some time to shutdown the socket. My previous tests (using pasynManager->isConnected to probe for connection status) seemed to show that it takes ~15min on this particular system for isConnected to go from 1 to 0. It also seems that by turning the controller back on isConnected goes from 0 to 1. So my current suspicion is in agreement with Mark's comments: something might be off in the interpose code.
I will continue investigating.
Thanks!
Bruno
On Thu, Feb 15, 2018 at 2:15 AM, Torsten Bögershausen <[email protected]> wrote:
On 12/02/18 20:45, Bruno Martins wrote:
Hi Mark,
We're using tpmac-asyn 3.10.12, asyn R4-32.
Hej Bruno,
what is tpmac-asyn 3.10.12 ?
The printouts you are pointing out ("command: #2 ? F P") seem to come from
.../epicsdeb/pmacasyn/pmacApp/pmacAsynMotorPortSrc/pmacAxis.cpp
Which seems to be a classic model 3 driver (?).
I am unsure which SW you are running.
Could you send us the whole st.cmd ?
And may be a receipe how to get the modules you are using,
tpmac-asyn, which motor. Are you using git clone ? Or wget ?
Regarding pmacAsynIPConfigure, it immediately calls drvAsynIPPortConfigure: https://github.com/epicsdeb/pmacasyn/blob/master/pmacApp/pmacAsynIPPortSrc/pmacAsynIPPort.c#L184 <https://github.com/epicsdeb/pmacasyn/blob/master/pmacApp/pmacAsynIPPortSrc/pmacAsynIPPort.c#L184>
You're right that the return code is asynError (from queueLockPort [asynManager.c:1832]) but queueRequest returns asynDisconnected [asynManager.c:1505]. I added more debugging.
I noticed two things:
1. If the IOC starts with the controller powered off, the above messages are printed. asyn/tpmac correctly knows the device is disconnected, but there's no attempt at a reconnection, so powering it on doesn't do anything. Here's the report in this case:
asynManager::queueLockPort queueRequest failed: port P0 not connected
2018/02/12 14:05:56.201 pmacController::lowLevelWriteRead: Error from pasynOctetSyncIO->writeRead. command: #2 ? F P
2018/02/12 14:05:56.201 drvPmacAxisGetStatus: not all status values returned. Status: 3
epics> asynReport 5 P0
P0 multiDevice:No canBlock:Yes autoConnect:Yes
     enabled:Yes connected:No numberConnects 0
     nDevices 0 nQueued 18 blocked:No
     asynManagerLock:No synchronousLock:Yes
     exceptionActive:No exceptionUsers 11 exceptionNotifys 0
     traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
     interposeInterfaceList
         asynOctet pinterface 0x7fcf1ca2c900 drvPvt 0xf5c060
     interfaceList
         asynCommon pinterface 0x7fcf1ca29650 drvPvt 0xf579e0
         asynOption pinterface 0x7fcf1ca29670 drvPvt 0xf579e0
         asynOctet pinterface 0xf57b00 drvPvt 0xf579e0
     Port 10.41.104.10:1025 <http://10.41.104.10:1025>: Disconnected
                     fd: -1
     Characters written: 0
        Characters read: 0
2. If the IOC starts with the controller powered on, everything works as expected:
     enabled:Yes connected:Yes numberConnects 1
     nDevices 0 nQueued 0 blocked:No
     asynManagerLock:No synchronousLock:No
         asynOctet pinterface 0x7fafe57dc900 drvPvt 0x1aa6090
     interfaceList
         asynCommon pinterface 0x7fafe57d9650 drvPvt 0x1aa1a10
         asynOption pinterface 0x7fafe57d9670 drvPvt 0x1aa1a10
         asynOctet pinterface 0x1aa1b30 drvPvt 0x1aa1a10
     Port 10.41.104.10:1025 <http://10.41.104.10:1025>: Connected
                     fd: 7
     Characters written: 9787
        Characters read: 5345
Then when we yank the power from the controller:
asynManager::queueLockPort queueRequest timed out
2018/02/12 14:33:03.069 pmacController::lowLevelWriteRead: Error from pasynOctetSyncIO->writeRead. command: #1 ? F P
2018/02/12 14:33:03.069 drvPmacAxisGetStatus: not all status values returned. Status: 3
     interfaceList
                     fd: 7
     Characters written: 26671
        Characters read: 11150
So it still thinks it is connected, even after quite some time.
I tried enabling the disconnectOnReadTimeout option, it yielded a weird behavior: with the motor controller powered ON, the IOC seems to start fine but then seems to disconnect from the controller by itself:
2018/02/12 14:40:38.972 pmacController::lowLevelWriteRead: Error from pasynOctetSyncIO->writeRead. command: #1 ? F P
2018/02/12 14:40:38.972 drvPmacAxisGetStatus: not all status values returned. Status: 3
     enabled:Yes connected:No numberConnects 1
     nDevices 0 nQueued 21 blocked:No
         asynOctet pinterface 0x7f5c7df24900 drvPvt 0x8f21a0
     interfaceList
         asynCommon pinterface 0x7f5c7df21650 drvPvt 0x8edb20
         asynOption pinterface 0x7f5c7df21670 drvPvt 0x8edb20
         asynOctet pinterface 0x8edc40 drvPvt 0x8edb20
                     fd: -1
     Characters written: 848
        Characters read: 470
Bruno
On Mon, Feb 12, 2018 at 1:32 PM, Mark Rivers <[email protected] <mailto:[email protected]du>> wrote:
    Hi Bruno,____
    __ __
    I think your startup script contains this command, correct?____
    __ __
    pmacAsynIPConfigure(portName, hostInfo)____
    __ __
    This means that the pmac driver is not directly communicating with the
    drvAsynIPPort driver supplied with asyn.  It is talking to the port created
    with the above command, which implements the asynInterposeInterface between
    the pmac motor driver and the underlying drvAsynIPPort driver.  I have not
    studied that code carefully, but it is possible that it is doing something
    to prevent the reconnect feature from working correctly.____
    __ __
    I have tested the asyn autoreconnect feature quite a bit recently, when I
    was trying to reduce the number of error messages that are printed when a
    device is powered off and then back on again.  For example, look at the
    Modbus R2-10 release notes:____
    __ __
    http://cars9.uchicago.edu/software/epics/modbusReleaseNotes.html
    <http://cars9.uchicago.edu/software/epics/modbusReleaseNotes.html>____
    __ __
    Mark____
    __ __
    __ __
    *From:*[email protected]nl.gov <mailto:tech-talk-bounces@aps.anl.gov>
    [mailto:tech-talk-bounces@aps.anl.gov
    <mailto:tech-talk-bounces@aps.anl.gov>] *On Behalf Of *Mark Rivers
    *Sent:* Monday, February 12, 2018 12:10 PM
    *To:* 'Bruno Martins' <[email protected]
    <mailto:[email protected]>>; [email protected]
    *Cc:* [email protected] <mailto:[email protected]>
    *Subject:* RE: PMAC asyn autoconnect issue____
    __ __
    Hi Bruno,____
    __ __
    What version of asyn are you using?____
    __ __
    What version of tpmac are you using?____
    __ __
    __Ø__2018/02/12 12:00:14.826 pmacController::lowLevelWriteRead: Error from
    2018/02/12 12:00:14.826 drvPmacAxisGetStatus: not all status values
    returned. Status: 3
    Command :#2 ? F P____
    __ __
    Note that Status: 3 is asynError, not asynDisconnected.____
    __ __
    Are you sure that asyn really thinks the port is disconnected at this
    time?  You should run asynReport on that port to see whether asyn thinks it
    is disconnected or not.____
    __ __
    One problem is that when you power-off an IP device on Linux it takes quite
    a while before the OS decides the socket is disconnected.  Before that time
    it returns an error like “Resource temporarily unavailable”.  During this
    time asyn will not try to reconnect, because it thinks it is still
    connected.____
    __ __
    This behavior is one reason that the drvAsynIPPort driver was enhanced in
    R4-29 to support the disconnectOnReadTimeout option.  If this option is
    enabled then the port will automatically disconnect whenever there is a
    read timeout.____
    __ __
    Mark____
    __ __
    __ __
    <mailto:tech-talk-bounces@aps.anl.gov>] *On Behalf Of *Bruno Martins
    *Sent:* Monday, February 12, 2018 11:34 AM
    *To:* [email protected] <mailto:[email protected]>
    *Subject:* PMAC asyn autoconnect issue____
    __ __
    Hi,____
    I've been investigating an issue with the PMAC driver regarding
    reconnection via Ethernet. When the controller is powered off the IOC
    starts emitting messages like the following (as expected):
    returned. Status: 3
    __ __
    __ __
    However, when the controller is powered on again, the IOC does not
    re-establish the connection (even though noAutoConnect is set to zero).____
    This is the sequence of calls that lead to these messages:____
    lowLevelWriteRead calls pasynOctetSyncIO->writeRead
    pasynOctetSyncIO->writeRead calls pasynManager->queueLockPort____
    pasynManager->queueLockPort calls pasynManager->queueRequest____
    queueRequest sets checkPortConnect = TRUE____
    __ __
    Since the port is disconnected, queueRequest returns an error
    https://github.com/epics-modules/asyn/blob/87e784335736de782980b7600bd7d6e42179511a/asyn/asynDriver/asynManager.c#L1505
    <https://github.com/epics-modules/asyn/blob/87e784335736de782980b7600bd7d6e42179511a/asyn/asynDriver/asynManager.c#L1505>____
    If checkPortConnected was FALSE autoConnectDevice would be called later on
    and a new connection would be attempted. But for this particular call chain
    checkPortConnected is always set to TRUE.____
    Now, since queueRequest fails a request is never queued and
    pasynManager->portThread's autoConnectDevice is also not reached.
    ____
    So my question is how to properly configure/trigger an auto connect?____
    __ __
    __ __
    PS.: I found this old thread that might be related:
    https://epics.anl.gov/tech-talk/2012/msg01216.php
    <https://epics.anl.gov/tech-talk/2012/msg01216.php>
    ____
    __ __
    Thanks!____
    Bruno____
Re: PMAC asyn autoconnect issue Bruno Martins
RE: PMAC asyn autoconnect issue Mark Rivers
Re: PMAC asyn autoconnect issue Torsten Bögershausen
Prev: Re: PMAC asyn autoconnect issue Torsten Bögershausen
Next: Mythen M1K - Low fps Nilson Pereira
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PMAC asyn autoconnect issue Bruno Martins
ANJ, 15 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
