What is the image size?
Are the frames being dropped in the NDStardardArray plugin? Or somewhere else?
Mark Rivers has allowed certain plugins to use multiple computational threads, so if they are dropping in NDStandardArray, you could try giving it more threads to see if added CPU resources change when your drop frames.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Nilson Pereira
Sent: Thursday, February 15, 2018 10:50 AM
To: [email protected]
Subject: Mythen M1K - Low fps
Hello everyone,
I started to work with a Dectris strip Detector Mythen2 X 1K and I am using the Mythen module from AreaDetector. This detector can reach 1000fps, however the IOC starts to drop frames with frequencies higher than 100fps.
Has anyone experience this limitation with this type of detector?
To avoid network issues, I have a straight network connection between the PC and detector.
I also noticed that the IOC only requests 1 frame at a time when it could (according to the manual) requests multiples frames to avoid communication overheads. Has anyone tried implementing this?
My versions:
- Ubuntu 16.04
- EPICS base 3.15.5
- ADCore 2-6
- ADMythen 2-0
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Mythen M1K - Low fps Nilson Pereira
Re: PMAC asyn autoconnect issue Bruno Martins
Re: PMAC asyn autoconnect issue Torsten Bögershausen
<2018>
2025
2026
RE: Mythen M1K - Low fps Mark Rivers
<2018>
2025
2026
