1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Other Access Security implementations?
To: <[email protected]>
Date: Thu, 15 Feb 2018 17:42:47 -0600
On 02/15/2018 05:04 PM, Konrad, Martin wrote:
> If our rules files become more complex in the future we might need to
> consider generating them using some tool that comes with a decent
> template engine. Since we are already using Puppet for managing our
> configuration files/IOCs this might be the way to go for the future.
> Using an appropriate Hiera data backend, Puppet could pull data from any
> data source (e.g. YAML files, SQL, LDAP,...). Maybe you have a similar
> configuration-management tool you can leverage?
For simple setups it is possible to use the GNU C pre-processor to
generate ACF files.
There are rules in the EPICS build system (in configure/RULES.Db) to
pass a .acs file through cpp to generate a .acf file. The .acs input
file can #include other files which use #define to create macros that
define common lists of users and machine names or even rules, then the
.acf files use these macros as needed by the IOC/subsystem.
The preprocessor does add "# <line> <file>" lines to the output files,
but asLib just ignores them as comments. You do have to use // and
/*...*/ comments in your .acs files instead of #<comment> though.
It ought to be possible to use msi too, but I haven't tried that.
- Andrew
Other Access Security implementations? Ralph Lange
Re: Other Access Security implementations? Konrad, Martin
Prev: Re: Other Access Security implementations? Konrad, Martin
Next: Re: Mythen M1K - Low fps Nilson Pereira
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Specs EBE-4 EPICS interface gary.yendell
ANJ, 16 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
