1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: using stream -calcout
To: tech-talk <[email protected]>
Date: Fri, 16 Feb 2018 18:27:55 +0800 (CST)
Hi all,
     I have a simple question about stream.
     The device was connected with LAN. If sending " fe 04 00 00 00 01 25 c5 " in Hex,  getting  " fe 04 02 04 08 ae 22 " in Hex.
     Among the getting bytes( " fe 04 02 04 08 ae 22 "), 04 08 was I wanted. Convert  0408(HEX) to decimal was 1032 (4*16**2 +8=1032), and 1032 was the finall result I wanted.
    In my programe, I have successfully sent and got the bytes. But I could not get the 1032, I want to achieve it using scalcout, but failed.
    Could you please give me some suggestion.
    The environment I use, base3.14.12.7, synapps_5_8, fedora 27(64).
my db file:
record(stringin, "GET_HIGH")
    field(DESC, "test for upstairs tcpip")
    field(DTYP, "stream")
    field(INP,  "@devtemp.proto get_high $(PORT) $(A)")
record(stringin, "GET_LOW")
    field(INP,  "@devtemp.proto get_low $(PORT) $(A)")
    field(SCAN, "I/O Intr")
record(scalcout, "TEM")
    field(DESC, "get the temperature")
    field(INPA, "GET_HIGH")
    field(INPB, "GET_LOW")
    field(CALC, "A*16*16 + B")
my proto file:
get_high {
   out "\xFE\x04\x00\x00\x00\x01\x25\xC5";
   in "%*c%*c%*c%*c%*c%*c%c%c%*c%*c%*c%*c%*c%*c";
#   in "%s";
get_low {
   in "%*c%*c%*c%*c%*c%*c%*c%*c%c%c%*c%*c%*c%*c";
output of  st.cmd: (there is an error "Record "TEM" is of unknown type "scalcout" )
#!../../bin/linux-x86_64/temp
## You may have to change temp to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioctemp")
epicsEnvSet("TOP","/home/lyx/tem_setup_with_asyn_scpi")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ASYN","/opt/epics/synApps_5_8/support/asyn-4-26")
epicsEnvSet("STREAM","/opt/epics/synApps_5_8/support/stream-2-6a")
epicsEnvSet "STREAM_PROTOCOL_PATH"  "/home/lyx/tem_setup_with_asyn_scpi/db"
epicsEnvSet "P" "P"
epicsEnvSet "R" "T"
cd "/home/lyx/tem_setup_with_asyn_scpi"
dbLoadDatabase "dbd/temp.dbd"
temp_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("L0","192.168.215.120:10000",0,0,0)
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
## Load record instances
dbLoadRecords("/home/lyx/tem_setup_with_asyn_scpi/db/devtemp.db","P=P,R=T,PORT=L0,A=0,user=lyxHost")
Error at or before ")" in file "/home/lyx/tem_setup_with_asyn_scpi/db/devtemp.db" line 25
cd "/home/lyx/tem_setup_with_asyn_scpi/iocBoot/ioctemp"
iocInit
Starting iocInit
## EPICS R3.14.12.7
## EPICS Base built Feb  7 2018
Li xing
Re: using stream -calcout Mooney, Tim M.
Re: using stream -calcout Ralph Lange
Re: using stream -calcout Dirk Zimoch
Prev: Re: Mythen M1K - Low fps Nilson Pereira
Next: Re: using stream -calcout Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
