1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Possible issue with epics-base 7 compilation
To: 'Andrew Johnson' <[email protected]>, "Gofron, Kazimierz" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 22 Feb 2018 19:35:41 +0000
I mentioned this in another thread, but I respond here too.
Using this 4.2.1 version I can now do "make -j" on my Windows 7 machine with various versions of Visual Studio (2010, 2015, 2017) and I have not yet seen a problem.  With the previous 4.1 version it would always hang with make -j in the areaDetector/ADSupport/supportApp/hdf5Src directory.  Make -j8 would work OK.
I have now built all of base 7.0.1 and synApps (including asyn, seq, areaDetector) with make -sj with no problems.
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Tuesday, February 13, 2018 3:41 PM
> To: Gofron, Kazimierz <[email protected]>; Mark Rivers <[email protected]>;
> [email protected]
> Subject: Re: Possible issue with epics-base 7 compilation
> Hi Guys,
> I don't know if an update will make any difference, but I just built a
> copy of the latest GNU make 4.2.1 which you can download from
>   https://epics.anl.gov/download/tools/make-4.2.1-win64.zip
> Please let us know if this helps.
> - Andrew
> On 02/12/2018 06:42 PM, Gofron, Kazimierz wrote:
> > Hi Mark,
> > Indeed it is make 4.1 from EPICS web page, that Andrew build.
> > Kaz
> > ________________________________________
> > From: Mark Rivers [[email protected]]
> > Sent: Monday, February 12, 2018 7:36 PM
> > To: Gofron, Kazimierz; [email protected]
> > Cc: [email protected]
> > Hi Kaz,
> > I don't think this is a new problem, and is not specific to EPICS 7.  Are you using the
> make 4.1 that Andrew built and put on the EPICS Web page?
> > If I run "make -sj" with that version then it will occasionally get into a state when one
> "make" process is using 100% of a core forever and it never completes.  This happens with
> 3.14.12.5, 3.15.5, and 7.0.1.1.
> > I have never had a problem if I use "make -sj8" on my 8-core machine.
> > Mark
> > From: Gofron, Kazimierz [mailto:[email protected]]
> > Sent: Monday, February 12, 2018 6:23 PM
> > To: [email protected]
> > Cc: Mark Rivers <[email protected]>; [email protected]
> > Subject: Possible issue with epics-base 7 compilation
> > Hi,
> > There is a possible threading issue when compiling epics-base 7 using 'make -sj'  on 8
> hyperthread system.
> > Observed on System X 3250 M5 with 8 hyperthreads, running windows 7 Professional,
> Xeon E3-1230 v3, and Visual Studio 2017.
> > make -sj never completes compilation
> > make -sj4 completes compilation
> > Compilation always successfully completes on Lenovo W550s laptop with 4 hyperthreads.
> > The two attached files show the two cases when compiling 'make' and 'make -sj' on the
> System X 3250 M5 (8 hyperthreads).
> > Kaz
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
Re: Possible issue with epics-base 7 compilation Andrew Johnson
RE: Possible issue with epics-base 7 compilation Gofron, Kazimierz
RE: Possible issue with epics-base 7 compilation Mark Rivers
Prev: Re: calc support compilation Mark Rivers
Next: Re: Possible issue with epics-base 7 compilation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: FW: Possible issue with epics-base 7 compilation Mark Rivers
ANJ, 23 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
