1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn not automatically reconnecting
To: "'Daykin, Evan'" <[email protected]>
Date: Tue, 27 Feb 2018 14:25:08 +0000
Hi Evan,
I have tried to reproduce your problem with a very simple server, EPICS database and StreamDevice protocol file.  I cannot reproduce the problem, automatic reconnection is working fine in my test.
Here is the test configuration:
- A simple "echo" server.  I am actually using the asyn/testAsynIPServerPort application for the server, but that should not be relevant.  It is simply a TCP server that accepts connections on port 5001 and echoes back every line it receives.
- This database file, stream1.db.  It consists of a stringout record that sends the string "Hello" to the server at 1Hz and a stringin record that reads the reply.
record(stringout,"$(P)$(R)testOut") {
    field(DTYP, "stream")
    field(OUT, "@stream1.proto stringOut $(PORT) 0 0")
    field(SCAN, "1 second")
    field(VAL, "Hello")
    field(FLNK, "$(P)$(R)testIn")
record(stringin,"$(P)$(R)testIn") {
    field(INP, "@stream1.proto stringIn $(PORT) 0 0")
- This protocol file, stream1.proto
stringOut {
   out "%s";
stringIn {
   in "%s";
This startup script, st.cmd.stream1.  It creates the drvAsynIPPort to port 5001 on my Linux server, and set the asyn trace mask to enable debugging.
< envPaths
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build from CARS
dbLoadDatabase("../../dbd/CARSLinux.dbd")
CARSLinux_registerRecordDeviceDriver(pdbbase)
drvAsynIPPortConfigure("ECHO","corvette.cars.aps.anl.gov:5001",0,0,0)
asynOctetSetInputEos(ECHO, 0, "\r\n")
asynOctetSetOutputEos(ECHO, 0, "\r\n")
asynSetTraceIOMask(ECHO, 0, 2)
asynSetTraceMask(ECHO, 0, 0XFF)
dbLoadRecords("stream1.db", "P=13TEST:, R=R:, PORT=ECHO")
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=13TEST:, R=asyn1, PORT=ECHO, ADDR=0, IMAX=80, OMAX=80")
iocInit
This is the output of the IOC running StreamDevice.  When I started this IOC the echo server was already running.
corvette:CARS/iocBoot/ioc13test>../../bin/linux-x86_64/CARSApp st.cmd.stream1
< envPaths
epicsEnvSet("IOC","ioc13test")
epicsEnvSet("TOP","/home/epics/devel/CARS")
epicsEnvSet("SUPPORT","/corvette/home/epics/devel")
epicsEnvSet("ALLEN_BRADLEY","/corvette/home/epics/devel/allenBradley-2-3")
epicsEnvSet("AREA_DETECTOR","/corvette/home/epics/devel/areaDetector-3-2")
epicsEnvSet("STREAM","/corvette/home/epics/devel/stream-2-7-7")
epicsEnvSet("TPMAC","/corvette/home/epics/devel/tpmac-3-11dls5")
epicsEnvSet("VME","/corvette/home/epics/devel/vme-2-8-2")
dbLoadRecords("/corvette/home/epics/devel/asyn-4-33/db/asynRecord.db", "P=13TEST:, R=asyn1, PORT=ECHO, ADDR=0, IMAX=80, OMAX=80")
iocInit
Starting iocInit
## EPICS R7.0.1.1
## EPICS Base built Jan  3 2018
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
2018/02/27 08:07:30.607 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:30.607 ECHO schedule queueRequest timeout
2018/02/27 08:07:30.607 asynManager::portThread port=ECHO callback
2018/02/27 08:07:30.607 13TEST:asyn1: asynCallbackSpecial, type=1
2018/02/27 08:07:30.607 13TEST:asyn1: getOptionCallback() port=ECHO, addr=0
2018/02/27 08:07:30.607 13TEST:asyn1: asynCallbackSpecial, type=3
2018/02/27 08:07:30.608 ECHO get Eos 2
\r\n
\r\n
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 37476,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2018-02-27T08:07:31.109 ServerContext configured with not Providers will do nothing!
epics> 2018/02/27 08:07:31.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:31.608 ECHO schedule queueRequest timeout
2018/02/27 08:07:31.608 asynManager::portThread port=ECHO callback
2018/02/27 08:07:31.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:31.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:07:31.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:07:31.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:07:31.609 ECHO wrote
Hello\r\n
2018/02/27 08:07:31.609 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:31.610 ECHO schedule queueRequest timeout
2018/02/27 08:07:31.610 asynManager::portThread port=ECHO callback
2018/02/27 08:07:31.610 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:31.610 corvette.cars.aps.anl.gov:5001 read 7
Hello\r\n
2018/02/27 08:07:31.610 ECHO read
Hello\r\n
epics>
epics> 2018/02/27 08:07:32.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:32.608 ECHO schedule queueRequest timeout
2018/02/27 08:07:32.608 asynManager::portThread port=ECHO callback
2018/02/27 08:07:32.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:32.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:07:32.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:07:32.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:07:32.609 ECHO wrote
Hello\r\n
2018/02/27 08:07:32.609 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:32.609 ECHO schedule queueRequest timeout
2018/02/27 08:07:32.609 asynManager::portThread port=ECHO callback
2018/02/27 08:07:32.609 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:32.609 corvette.cars.aps.anl.gov:5001 read 7
Hello\r\n
2018/02/27 08:07:32.609 ECHO read
Hello\r\n
2018/02/27 08:07:41.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:41.608 ECHO schedule queueRequest timeout
2018/02/27 08:07:41.608 asynManager::portThread port=ECHO callback
2018/02/27 08:07:41.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:41.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:07:41.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:07:41.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:07:41.609 ECHO wrote
Hello\r\n
At this point I closed the echo server.  Note that StreamDevice prints error messages saying that port ECHO is not connected.
2018/02/27 08:07:41.609 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:41.609 ECHO schedule queueRequest timeout
2018/02/27 08:07:41.609 asynManager::portThread port=ECHO callback
2018/02/27 08:07:41.609 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:41.609 corvette.cars.aps.anl.gov:5001 read 0
2018/02/27 08:07:41.609 Close corvette.cars.aps.anl.gov:5001 connection (fd 6): Read from broken connection
2018/02/27 08:07:41.609 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:07:41.609 ECHO read
2018/02/27 08:07:41.614 ECHO addr -1 queueRequest priority 3 not lockHolder
2018/02/27 08:07:41.615 asynManager connect queueCallback port:ECHO
2018/02/27 08:07:41.615 Open connection to corvette.cars.aps.anl.gov:5001  reason:0  fd:-1
2018/02/27 08:07:41.615 Opened connection to corvette.cars.aps.anl.gov:5001
2018/02/27 08:07:41.615 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:07:42.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:07:42.608 ECHO schedule queueRequest timeout
2018/02/27 08:07:42.608 asynManager::portThread port=ECHO callback
2018/02/27 08:07:42.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:07:42.608 corvette.cars.aps.anl.gov:5001 read 0
2018/02/27 08:07:42.608 Close corvette.cars.aps.anl.gov:5001 connection (fd 6): Read from broken connection
2018/02/27 08:07:42.608 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:07:42.608 ECHO read
2018/02/27 08:07:42.608 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:07:42.608 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:07:42.608155 ECHO 13TEST:R:testOut: write failed because connection was closed by device
2018/02/27 08:07:42.608212 cbLow 13TEST:R:testIn readRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:42.613 ECHO addr -1 queueRequest priority 3 not lockHolder
2018/02/27 08:07:42.613 asynManager connect queueCallback port:ECHO
2018/02/27 08:07:42.613 Open connection to corvette.cars.aps.anl.gov:5001  reason:0  fd:-1
2018/02/27 08:07:43.607857 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:44.607851 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:45.607854 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:46.607887 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:47.607860 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:48.607875 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:49.607840 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:50.607871 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:51.607878 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
Sometime around here I restarted the echo server.  StreamDevice continued to print error messages for some time, but then it automatically reconnected and things started working again.
2018/02/27 08:07:52.607871 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:53.607863 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:54.607882 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:55.607849 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:56.607837 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:57.607858 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:58.607837 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:07:59.607849 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:00.607839 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:01.607851 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:02.607852 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:02.608 ECHO addr -1 queueRequest priority 3 not lockHolder
2018/02/27 08:08:02.608 asynManager connect queueCallback port:ECHO
2018/02/27 08:08:02.608 Open connection to corvette.cars.aps.anl.gov:5001  reason:0  fd:-1
2018/02/27 08:08:02.609 Opened connection to corvette.cars.aps.anl.gov:5001
2018/02/27 08:08:02.609 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:08:03.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:08:03.608 ECHO schedule queueRequest timeout
2018/02/27 08:08:03.608 asynManager::portThread port=ECHO callback
2018/02/27 08:08:03.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:08:03.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:08:03.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:08:03.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:08:03.609 ECHO wrote
Hello\r\n
2018/02/27 08:08:04.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:08:04.608 ECHO schedule queueRequest timeout
2018/02/27 08:08:04.608 asynManager::portThread port=ECHO callback
2018/02/27 08:08:04.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:08:04.608 corvette.cars.aps.anl.gov:5001 read 7
Hello\r\n
2018/02/27 08:08:04.608 ECHO read
Hello\r\n
At this point I closed the echo server again, and restarted it a few seconds later.  Note again that StreamDevice prints the error messages, but the port reconnects and it continues normally.
2018/02/27 08:08:24.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:08:24.609 ECHO wrote
Hello\r\n
2018/02/27 08:08:25.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:08:25.608 ECHO schedule queueRequest timeout
2018/02/27 08:08:25.608 asynManager::portThread port=ECHO callback
2018/02/27 08:08:25.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:08:25.608 corvette.cars.aps.anl.gov:5001 read 0
2018/02/27 08:08:25.608 Close corvette.cars.aps.anl.gov:5001 connection (fd 6): Read from broken connection
2018/02/27 08:08:25.608 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:08:25.608 ECHO read
2018/02/27 08:08:25.608 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:08:25.608 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:08:25.608126 ECHO 13TEST:R:testOut: write failed because connection was closed by device
2018/02/27 08:08:25.613 ECHO addr -1 queueRequest priority 3 not lockHolder
2018/02/27 08:08:25.613 asynManager connect queueCallback port:ECHO
2018/02/27 08:08:25.613 Open connection to corvette.cars.aps.anl.gov:5001  reason:0  fd:-1
2018/02/27 08:08:26.607863 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:27.607856 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:28.607836 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:29.607870 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:30.607850 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:31.607868 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:32.607850 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:33.607841 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:34.607836 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:35.607849 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:36.607865 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:37.607835 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:38.607862 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:39.607859 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:40.607851 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:41.607838 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:42.607856 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:43.607857 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:44.607863 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:45.607856 scan-1 13TEST:R:testOut lockRequest: pasynManager->queueRequest() failed: port ECHO not connected
2018/02/27 08:08:45.608 ECHO addr -1 queueRequest priority 3 not lockHolder
2018/02/27 08:08:45.608 asynManager connect queueCallback port:ECHO
2018/02/27 08:08:45.608 Open connection to corvette.cars.aps.anl.gov:5001  reason:0  fd:-1
2018/02/27 08:08:45.609 Opened connection to corvette.cars.aps.anl.gov:5001
2018/02/27 08:08:45.609 13TEST:asyn1: exception 0, asynExceptionConnect
2018/02/27 08:08:46.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:08:46.608 ECHO schedule queueRequest timeout
2018/02/27 08:08:46.608 asynManager::portThread port=ECHO callback
2018/02/27 08:08:46.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:08:46.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:08:46.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:08:46.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
2018/02/27 08:08:46.609 ECHO wrote
Hello\r\n
2018/02/27 08:08:47.608 ECHO addr -1 queueRequest priority 0 not lockHolder
2018/02/27 08:08:47.608 ECHO schedule queueRequest timeout
2018/02/27 08:08:47.608 asynManager::portThread port=ECHO callback
2018/02/27 08:08:47.608 corvette.cars.aps.anl.gov:5001 read.
2018/02/27 08:08:47.608 corvette.cars.aps.anl.gov:5001 read 7
Hello\r\n
2018/02/27 08:08:47.608 ECHO read
Hello\r\n
2018/02/27 08:08:47.609 corvette.cars.aps.anl.gov:5001 write.
2018/02/27 08:08:47.609 corvette.cars.aps.anl.gov:5001 write 7
Hello\r\n
2018/02/27 08:08:47.609 wrote 7 to corvette.cars.aps.anl.gov:5001, return asynSuccess.
So in this simple test automatically reconnect when the server shuts down and comes back up is working with StreamDevice.
I think you need to figure out what is different about your system.  Can you create a very simple protocol file and database to test your server with, like this one?
> -----Original Message-----
> From: Daykin, Evan [mailto:[email protected]]
> Sent: Monday, February 26, 2018 9:01 AM
> To: Mark Rivers <[email protected]>
> Cc: [email protected]
> Manually reconnecting using the asyn record GUI did not work. The Shell yields:
> 2018/02/26 09:58:54.559 _TEST-RF-DCU-N0001:asyn: queueRequest failed
> 2018/02/26 09:59:00.162 _TEST-RF-DCU-N0001:asyn: special queueRequest timeout
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, February 23, 2018 3:33 PM
> To: Daykin, Evan <[email protected]>
> Subject: Re: Asyn not automatically reconnecting
> I am not familiar with this. Can you show me where to find that?
> There is an medm screen for the asyn record in asyn. On the master branch there is also a
> CSS screen I think.  The CNCT field let's you manually connect/disconnect.  You can do
> this with caput as well. Look at the asyn record documentation.
> Mark
> Sent from my iPhone
> On Feb 23, 2018, at 2:13 PM, Daykin, Evan
> <[email protected]<mailto:[email protected]>> wrote:
> When your client shuts down it does so "cleanly", closing the socket?  It looks like it, since
> drvAsynIPPort detected the closed connection immediately, without first getting any
> timeouts, etc.
> Yes, I just verified this with wireshark. The TCP connection is closed gracefully. Netstat on
> both ends shows there is no connection as well.
> When the client comes back up do you see any different messages?
> No, the "...read." message just repeats extremely quickly.
> When the client comes back up you can trying using the asynRecord GUI to try to manually
> reconnect.  Does that work?
> Something else interesting is that rebooting results in the correct behavior; the connection is
> re-established. However, if the controlling process on the client device is killed first, this
> issue persists.
> -Evan
> Sent: Friday, February 23, 2018 10:49 AM
> To: Daykin, Evan <[email protected]<mailto:[email protected]>>; tech-
> Hi Evan,
> timeouts, etc.
> Mark
> ________________________________
> From: Daykin, Evan <[email protected]<mailto:[email protected]>>
> Sent: Friday, February 23, 2018 8:55 AM
> To: Mark Rivers; [email protected]<mailto:[email protected]>
> Here is the output from the moment I killed the connection:
> 2018/02/23 09:51:47.086 TEST-RF-DCU-N0001 read
> VALUE AMP_WATER_FLOW AMP 2 7.0049e-168\n
> 2018/02/23 09:51:47.087 TEST-RF-DCU-N0001 set Eos 0
> 2018/02/23 09:51:47.087 asynManager::portThread port=TEST-RF-DCU-N0001 callback
> 2018/02/23 09:51:47.087 TEST-RF-DCU-N0001 addr -1 queueRequest priority 0 not
> lockHolder
> 2018/02/23 09:51:47.088 TEST-RF-DCU-N0001 schedule queueRequest timeout
> 2018/02/23 09:51:47.088 asynManager::portThread port=TEST-RF-DCU-N0001 callback
> 2018/02/23 09:51:47.088 test-rf-dcu-n0001.cts:5001 read.
> 2018/02/23 09:51:47.088 test-rf-dcu-n0001.cts:5001 read 0
> 2018/02/23 09:51:47.088 Close test-rf-dcu-n0001.cts:5001 connection (fd 18): Read from
> broken connection
> 2018/02/23 09:51:47.088 _TEST-RF-DCU-N0001:asyn: exception 0,
> 2018/02/23 09:51:47.088 TEST-RF-DCU-N0001 read
> 2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
> The last line then repeats rapidly forever.
> Sent: Friday, February 23, 2018 9:20 AM
> Can you set the asynTraceIOMask to 2 and the asynTraceMask to 0xff on that port just
> before you shut down the client?
> Sent: Friday, February 23, 2018 8:18 AM
> To: Mark Rivers
> <[email protected]<mailto:[email protected]><mailto:[email protected].
> edu>>; [email protected]<mailto:[email protected]><mailto:tech-
> [email protected]>
> Hi Mark,
> Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The protocol file has a
> ReplyTimeout of 2000ms.
> Sent: Thursday, February 22, 2018 6:20 PM
> To: Daykin, Evan
> <[email protected]<mailto:[email protected]><mailto:[email protected]>>;
> Hi Evan,
> Ø  We have client devices that, when remotely updated and rebooted, the IOC does not
> attempt to reconnect automatically
> Ø  TEST-RF-DCU-N0001 multiDevice:No canBlock:Yes autoConnect:Yes
> Ø  enabled:Yes connected:No numberConnects 1
> Ø  nDevices 0 nQueued 114 blocked:No
> The above information says that indeed autoConnect is set to Yes, and it is currently not
> connected.  The 114 entries in the queue seems strange.
> What version of asyn and what version of StreamDevice are you using?  What you are
> observing does not seem correct.
> What timeouts if any have you specified in your protocol file?
> Mark
> From: [email protected]<mailto:[email protected]><mailto:tech-
> [email protected]> [mailto:[email protected]] On Behalf Of Daykin,
> Evan
> Sent: Thursday, February 22, 2018 4:32 PM
> To: [email protected]<mailto:[email protected]><mailto:[email protected]>
> Subject: Asyn not automatically reconnecting
> Hello,
> Apologies if this has already been asked and answered. We have client devices that, when
> remotely updated and rebooted, the IOC does not attempt to reconnect automatically. Any
> records tied to it simply enter a TIMEOUT_ALARM state, and no asyn or StreamDevice
> error messages are printed.  autoConnect is not specified in drvAsynIPPortconfigure, which,
> according to the documentation, implicitly enables autoConnect/attempting to reconnect
> every 20 seconds.  Does anything else need to be done?
> The devices are configured to communicate using Stream Device.
> Relevant asyn configuration in the startup script:
> -drvAsynIPPortConfigure("TEST-RF-DCU-N0001",  "test-rf-dcu-n0001.cts:5001")
> asynReport after client is disconnected and brought back up:
>    asynManagerLock:No synchronousLock:Yes
>    exceptionActive:No exceptionUsers 2 exceptionNotifys 0
>    traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
>    interposeInterfaceList
>        asynOctet pinterface 0x7f0a07506900 drvPvt 0x6c3720
>    interfaceList
>        asynCommon pinterface 0x7f0a07502650 drvPvt 0x6bfe30
>        asynOption pinterface 0x7f0a07502670 drvPvt 0x6bfe30
>        asynOctet pinterface 0x6bff50 drvPvt 0x6bfe30
>    Port test-rf-dcu-n0001.cts:5001: Disconnected
>                    fd: -1
>    Characters written: 127036
>       Characters read: 138000
> -Evan
Asyn not automatically reconnecting Daykin, Evan
RE: Asyn not automatically reconnecting Daykin, Evan
Prev: Re: Device Net driver support for MKS bob dalesio
Next: RE: Device Net driver support for MKS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Asyn not automatically reconnecting Daykin, Evan
Next: RE: Asyn not automatically reconnecting Daykin, Evan
ANJ, 27 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
