Can you try a very simple database with just one or two records talking to your server. See if that works when the server shuts down gracefully. If it does, but it fails with lots of records then we have a clue where to look.
Sent: Tuesday, February 27, 2018 3:53 PM
To: Torsten Bögershausen; Mark Rivers; [email protected]
Subject: RE: Asyn not automatically reconnecting
>Sorry if this is the wrong question, but what is asyn 4.33-2 ?
>"git tag" mentions R4-33, not "-2".
That's the revision in our debian repo, it is asyn 4-33.
> So from asyn everything seems to be OK.
Maybe this is streamdevice and/or our vendor's software. We will investigate both avenues.
-----Original Message-----
From: Torsten Bögershausen [mailto:[email protected]]
Sent: Tuesday, February 27, 2018 3:37 PM
To: Daykin, Evan <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Subject: Re: Asyn not automatically reconnecting
On 23/02/18 15:17, Daykin, Evan wrote:
> Hi Mark,
> Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The
> protocol file has a ReplyTimeout of 2000ms.
And to answer the other question:
>Here's something interesting: asyn behaves correctly for us *only* when the >client application is killed with SIGKILL, rather than SIGTERM. This results >in TCP retransmissions and/or refused connections, then normal operation after >a short while. Is it possible asyn is [un]intentionally not retrying the >connection if it is closed gracefully?
The code that I see producing "Read from broken connection" is this:
/* If recv() returns 0 on a SOCK_STREAM (TCP) socket, the connection has closed */
if ((thisRead == 0) && (tty->socketType == SOCK_STREAM)) {
epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
"%s connection closed",
tty->IPDeviceName);
closeConnection(pasynUser,tty,"Read from broken connection");
And then
closeConnection(asynUser *pasynUser,ttyController_t *tty,const char *why) {
asynPrint(pasynUser, ASYN_TRACE_FLOW,
"Close %s connection (fd %d): %s\n", tty->IPDeviceName, tty->fd, why);
It seems that the problem described here:
>2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
>The last line then repeats rapidly forever.
is caused by the caller into asyn, which is streamdevice ?
There seem to be some improvements in streamdevice, but I am not familiar with the code.
Dirk, does there ring a bell ?
- Asyn not automatically reconnecting Daykin, Evan
- RE: Asyn not automatically reconnecting Daykin, Evan
Re: Idea for new Display Manager Whitney R. Armstrong
<2018>
2025
2026
<2018>
2025
2026
