1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn not automatically reconnecting
To: Mark Rivers <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 1 Mar 2018 21:04:05 +0000
I have tried a database with only a couple of records, and the behavior persists.
-----Original Message-----
Sent: Tuesday, February 27, 2018 4:57 PM
To: Daykin, Evan <[email protected]>; Torsten Bögershausen <[email protected]>; [email protected]
Subject: Re: Asyn not automatically reconnecting
Can you try a very simple database with just one or two records talking to your server.  See if that works when the server shuts down gracefully.  If it does, but it fails with lots of records then we have a clue where to look.
Sent: Tuesday, February 27, 2018 3:53 PM
To: Torsten Bögershausen; Mark Rivers; [email protected]
>Sorry if this is the wrong question, but what is asyn 4.33-2 ?
>"git tag" mentions R4-33, not "-2".
That's the revision in our debian repo, it is asyn 4-33.
> So from asyn everything seems to be OK.
Maybe this is streamdevice and/or our vendor's software. We will investigate both avenues.
From: Torsten Bögershausen [mailto:[email protected]]
Sent: Tuesday, February 27, 2018 3:37 PM
To: Daykin, Evan <[email protected]>; Mark Rivers <[email protected]>; [email protected]
On 23/02/18 15:17, Daykin, Evan wrote:
> Hi Mark,
> Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The
> protocol file has a ReplyTimeout of 2000ms.
And to answer the other question:
 >Here's something interesting: asyn behaves correctly for us *only* when the  >client application is killed with SIGKILL, rather than SIGTERM. This results  >in TCP retransmissions and/or refused connections, then normal operation after >a short while.  Is it possible asyn is [un]intentionally not retrying the >connection if it is closed gracefully?
The code that I see producing "Read from broken connection" is this:
     /* If recv() returns 0 on a SOCK_STREAM (TCP) socket, the connection has closed */
     if ((thisRead == 0) && (tty->socketType == SOCK_STREAM)) {
         epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
                       "%s connection closed",
                       tty->IPDeviceName);
         closeConnection(pasynUser,tty,"Read from broken connection");
And then
closeConnection(asynUser *pasynUser,ttyController_t *tty,const char *why) {
     asynPrint(pasynUser, ASYN_TRACE_FLOW,
               "Close %s connection (fd %d): %s\n", tty->IPDeviceName, tty->fd, why);
It seems that the problem described here:
 >2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
 >The last line then repeats rapidly forever.
is caused by the caller into asyn, which is streamdevice ?
There seem to be some improvements in streamdevice, but I am not familiar with the code.
Dirk, does there ring a bell  ?
RE: Asyn not automatically reconnecting Mark Rivers
Asyn not automatically reconnecting Daykin, Evan
RE: Asyn not automatically reconnecting Daykin, Evan
Prev: Re: Idea for new Display Manager keith.thorne
Next: RE: Asyn not automatically reconnecting Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn not automatically reconnecting Mark Rivers
ANJ, 01 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
