1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: measComp R1-5 released
Date: Fri, 2 Mar 2018 16:57:22 +0000
Folks,
Release 1-5 of the measComp module is now available.
This is from the release notes:
- Added support to drvMultiFunction for the E-1608. This is an Ethernet module with analog input, analog output, digital I/O, and a counter. Added new medm screen E1608_module.adl and new iocBoot directory, iocE1608. This device is useful in applications where the length limitation of USB and/or the ability to move around without an attached computer are important.
- Renamed 1608GCounter.template to measCompCounter.template, since it is a generic file.
- Changed line endings in all .substitutions files to be Linux.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: Re: Asyn not automatically reconnecting Mark Rivers
Next: Re: Communicate between XML-RPC system and EPICS Channel Access? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Communicate between XML-RPC system and EPICS Channel Access? Andrew Johnson
Next: Systems Engineer Position at Sigray David Vine
ANJ, 02 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
