Hi Evan,
Can you do the following when you are in that state:
- Turn off the message blast with
asynSetTraceMask $(HWUNIT) 0 0
- Get a report on the state of the driver with:
asynReport 10 $(HWUNIT)
I want to see if the port thinks it is connected or not.
One thing I notice:
> [../../asyn/drvAsynSerial/drvAsynIPPort.c:674] [TEST-RF-DCU-N0001,0x260d420,50] test-rf-dcu-n0001.cts:5001 read.
It appears that the IP name of the IOC is test-rf-dcu-n0001.cts ? Is that true? Is the .cts actually part of this host's name? If so, does that violate the rules for valid host names?
https://en.wikipedia.org/wiki/Hostname#Restrictions_on_valid_hostnames
Sent: Friday, March 2, 2018 7:49 AM
To: Mark Rivers; Torsten Bögershausen; [email protected]
Subject: RE: Asyn not automatically reconnecting
Just the last one. It repeats on the order of hundreds of times a second.
-----Original Message-----
Sent: Thursday, March 01, 2018 4:56 PM
To: Daykin, Evan <[email protected]>; Torsten Bögershausen <[email protected]>; [email protected]
> 2018/03/01 16:29:14.902 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/miscellaneous/asynInterposeEos.c:235]
> [TEST-RF-DCU-N0001,0x260d420,50] TEST-RF-DCU-N0001 read
> (Repeats forever)
What repeats forever? Both of these lines or just the second one? Does it repeat very fast? How many times/second?
> From: Daykin, Evan [mailto:[email protected]]
> Sent: Thursday, March 01, 2018 3:34 PM
> To: Mark Rivers <[email protected]>; Torsten Bögershausen
> Sure,
> Database:
> record(asyn, "_$(HWUNIT):asyn") #resolves to PORT name {
> field(PORT, "$(HWUNIT)")
> field(IEOS, "\n")
> field(OEOS, "\n")
> field(ASG, "$(ASGEXPERT)")
> record(ai, "TEST:POWR_RD_FWD")
> field(DESC, "AMP_PWR_FORWARD value")
> field(DTYP, "stream")
> field(SCAN, "5 second")
> field(EGU, "W")
> field(INP, "@HBH-RF-Amp.proto getAmpValue(AMP_PWR_FORWARD,1) TEST-
> RF-DCU-N0001")
> info(archive, " ")
> Protocol file:
> Terminator = LF;
> ReplyTimeout = 2000;
> getUnitError {
> ExtraInput = Ignore;
> out "GET ERROR AMP \$1";
> in "%64c";
> clearAmpError {
> out "CLEAR ERROR AMP \$1";
> in "OK ERROR LIST cleared";
> resetAmp {
> out "RESET AMP \$1";
> in "OK";
> getAmpOn {
> out "GET PWR AMP \$1";
> in "POWER AMP \$1 %{OFF|ON}";
> setAmpOn {
> out "SET PWR AMP \$1 %{OFF|ON}";
> in "OK";
> getAmpValue {
> out "GET VALUE \$1 AMP \$2";
> in "VALUE \$1 AMP \$2 %g";
> getAmpThreshold {
> out "GET THRESHOLD \$1 AMP \$2";
> in "THRESHOLD \$1 AMP \$2 %g";
> setAmpThreshold {
> out "SET THRESHOLD \$1 AMP \$2 %g";
> in "OK";
> ## @init { getAmpThreshold; }
> getAmpPhase {
> out "GET PHASE AMP \$1";
> in "PHASE AMP \$1 %d";
> setAmpPhase {
> out "SET PHASE AMP \$1 %d";
> in "OK";
> getDrawerPhase {
> out "GET PHASE DRAWER \$1";
> in "PHASE DRAWER \$1 %d";
> setDrawerPhase {
> out "SET PHASE DRAWER \$1 %d";
> in "OK";
> getDrawerValue {
> out "GET VALUE \$1 AMP \$2 DRAWER \$3";
> in "VALUE \$1 AMP \$2 DRAWER \$3 %g"; }
> getDrawerValueInt {
> in "VALUE \$1 AMP \$2 DRAWER \$3 %d"; }
> getDrawerThreshold {
> out "GET THRESHOLD \$1 AMP \$2 DRAWER \$3";
> in "THRESHOLD \$1 AMP \$2 DRAWER \$3 %g"; }
> setDrawerThreshold {
> out "SET THRESHOLD \$1 AMP \$2 DRAWER \$3 %g";
> in "OK";
> getPalletValue {
> out "GET VALUE \$1 AMP \$2 DRAWER \$3 PALLET \$4";
> in "VALUE \$1 AMP \$2 DRAWER \$3 PALLET \$4 %g"; }
> getPalletThreshold {
> out "GET THRESHOLD \$1 AMP \$2 DRAWER \$3 PALLET \$4";
> in "THRESHOLD \$1 AMP \$2 DRAWER \$3 PALLET \$4 %g"; }
> setPalletThreshold {
> out "SET THRESHOLD \$1 AMP \$2 DRAWER \$3 PALLET \$4 %g";
> in "OK";
> ## @init { getPalletThreshold; }
> getFirmwareVersionDCU {
> out "GET VALUE VERSION_SOFTWARE AMP \$1";
> in "VALUE VERSION_SOFTWARE AMP \$1 %s"; }
> getFirmwareVersionDrawer {
> out "GET VALUE VERSION_SOFTWARE AMP \$1 DRAWER \$2";
> in "VALUE VERSION_SOFTWARE AMP \$1 DRAWER \$2 %s"; }
> getFirmwareVersionPallet {
> out "GET VALUE VERSION_SOFTWARE AMP \$1 DRAWER \$2 PALLET \$3";
> in "VALUE VERSION_SOFTWARE AMP \$1 DRAWER \$2 PALLET \$3 %s"; }
> Asyn IO output (properly functioning):
> 2018/03/01 16:17:49.155 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/asynDriver/asynManager.c:1560]
> [TEST-RF-DCU-N0001,0x6d72f0,50] TEST-
> RF-DCU-N0001 addr -1 queueRequest priority 0 from lockHolder
> [../../asyn/asynDriver/asynManager.c:1576]
> RF-DCU-N0001 schedule queueRequest timeout
> [../../asyn/asynDriver/asynManager.c:886]
> [TEST-RF-DCU-N0001,0x6d72f0,50] asynManager::portThread
> port=TEST-RF-DCU-N0001 callback
> [../../asyn/miscellaneous/asynInterposeEos.c:337]
> TEST-RF-DCU-N0001 get Eos 0
> [../../asyn/miscellaneous/asynInterposeEos.c:295]
> TEST-RF-DCU-N0001 set Eos 1
> \n
> 0a
> [TEST-RF-DCU-N0001,0x6d72f0,50] test-
> 2018/03/01 16:17:50.320 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/drvAsynSerial/drvAsynIPPort.c:203]
> [TEST-RF-DCU-N0001,0x6d72f0,50] Close
> test-rf-dcu-n0001.cts:5001 connection (fd 6): Read error
> [../../asyn/asynRecord/asynRecord.c:905]
> [TEST-RF-DCU-N0001,0x6d72f0,50] _TEST-
> RF-DCU-N0001:asyn: exception 0, asynExceptionConnect
> 2018/03/01 16:17:50.319943 TEST-RF-DCU- TEST:POWR_RD_FWD: asynError in read:
> test-rf-dcu-n0001.cts:5001 read error: Connection reset by peer
> 2018/03/01 16:17:50.319959 TEST-RF-DCU- TEST:POWR_RD_FWD: I/O error
> after reading 0 bytes: ""
> 2018/03/01 16:17:50.319981 TEST-RF-DCU- TEST:POWR_RD_FWD: Protocol
> aborted
> TEST-RF-DCU-N0001 set Eos 0
> 2018/03/01 16:17:50.325 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/asynDriver/asynManager.c:1565] [timerQueue,0x6d5fd0,60]
> TEST-RF-DCU-
> N0001 addr -1 queueRequest priority 3 not lockHolder
> [../../asyn/asynDriver/asynManager.c:807]
> [TEST-RF-DCU-N0001,0x6d72f0,50] asynManager connect queueCallback
> port:TEST-RF-DCU-N0001
> [../../asyn/drvAsynSerial/drvAsynIPPort.c:402]
> [TEST-RF-DCU-N0001,0x6d72f0,50] Open connection to
> test-rf-dcu-n0001.cts:5001 reason:0 fd:-1
> 2018/03/01 16:17:50.326 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/drvAsynSerial/drvAsynIPPort.c:508]
> [TEST-RF-DCU-N0001,0x6d72f0,50] Opened connection to
> 2018/03/01 16:17:54.153 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/asynDriver/asynManager.c:1565] [scan-5,0x718ec0,61]
> TEST-RF-DCU-N0001 addr -1 queueRequest priority 0 not lockHolder
> [../../asyn/asynDriver/asynManager.c:1576] [scan-5,0x718ec0,61]
> TEST-RF-DCU-N0001 schedule queueRequest timeout
> 2018/03/01 16:17:54.154 [TEST-RF-DCU-N0001,-1,0]
> [../../asyn/drvAsynSerial/drvAsynIPPort.c:744]
> rf-dcu-n0001.cts:5001 read 50
> FRIB Control Unit (0.4.8 GU Jan 2 2018 21:32:44)
> Asyn output (not working):
> [../../asyn/asynDriver/asynManager.c:1565] [scan-5,0x264e600,61]
> [../../asyn/asynDriver/asynManager.c:1576] [scan-5,0x264e600,61]
> [TEST-RF-DCU-N0001,0x260d420,50] asynManager::portThread
> test-rf-dcu-n0001.cts:5001 read 0
> [TEST-RF-DCU-N0001,0x260d420,50] Close test-rf-dcu-n0001.cts:5001
> connection (fd 18): Read from broken connection
> [TEST-RF-DCU-N0001,0x260d420,50] _TEST-
> test-rf-dcu-n0001.cts:5001 read. (Repeats forever)
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, March 01, 2018 4:06 PM
> Can you post the database, protocol file, and asynTrace output with all asynTrace bits on?
> > Sent: Thursday, March 01, 2018 3:04 PM
> > I have tried a database with only a couple of records, and the behavior persists.
> > Sent: Tuesday, February 27, 2018 4:57 PM
> > Subject: Re: Asyn not automatically reconnecting
> > Can you try a very simple database with just one or two records
> > talking to your server. See if that works when the server shuts
> > down gracefully. If it does, but it fails with lots of records then we have a clue where to look.
> > Mark
> > ________________________________
> > From: Daykin, Evan <[email protected]>
> > Sent: Tuesday, February 27, 2018 3:53 PM
> > To: Torsten Bögershausen; Mark Rivers; [email protected]
> > >Sorry if this is the wrong question, but what is asyn 4.33-2 ?
> > >"git tag" mentions R4-33, not "-2".
> > That's the revision in our debian repo, it is asyn 4-33.
> > > So from asyn everything seems to be OK.
> > Maybe this is streamdevice and/or our vendor's software. We will
> > investigate both
> avenues.
> > From: Torsten Bögershausen [mailto:[email protected]]
> > Sent: Tuesday, February 27, 2018 3:37 PM
> > To: Daykin, Evan <[email protected]>; Mark Rivers
> > <[email protected]>; tech- [email protected]
> > On 23/02/18 15:17, Daykin, Evan wrote:
> > > Hi Mark,
> > > Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3.
> > > The protocol file has a ReplyTimeout of 2000ms.
> > And to answer the other question:
> > >Here's something interesting: asyn behaves correctly for us *only*
> > when the >client application is killed with SIGKILL, rather than
> > SIGTERM. This results >in TCP retransmissions and/or refused
> > connections, then normal operation after >a short while. Is it
> > possible asyn is
> [un]intentionally not retrying the >connection if it is closed gracefully?
> > The code that I see producing "Read from broken connection" is this:
> > /* If recv() returns 0 on a SOCK_STREAM (TCP) socket, the connection has closed */
> > if ((thisRead == 0) && (tty->socketType == SOCK_STREAM)) {
> > epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
> > "%s connection closed",
> > tty->IPDeviceName);
> > closeConnection(pasynUser,tty,"Read from broken
> > connection");
> > And then
> > closeConnection(asynUser *pasynUser,ttyController_t *tty,const char *why) {
> > asynPrint(pasynUser, ASYN_TRACE_FLOW,
> > "Close %s connection (fd %d): %s\n",
> > tty->IPDeviceName,
> > tty->fd, why);
> > It seems that the problem described here:
> > >2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
> > >The last line then repeats rapidly forever.
> > is caused by the caller into asyn, which is streamdevice ?
> > There seem to be some improvements in streamdevice, but I am not familiar with the code.
> > Dirk, does there ring a bell ?
- Asyn not automatically reconnecting Daykin, Evan
- RE: Asyn not automatically reconnecting Daykin, Evan
Re: Asyn not automatically reconnecting Torsten Bögershausen
measComp R1-5 released Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
