1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Mako G-234B (6408) - Prosilica Area Detector question
To: <[email protected]>, "'Mark Rivers'" <[email protected]>
Date: Fri, 9 Mar 2018 09:36:33 -0600
Mark,
I recently deployed  a GigE camera Mako G-234B from Allied Vision with the Prosilica Area Detector but noticed a bit of oddness with the expected frame rate. The camera data sheet lists 41.2 FPS as the readout rate,10-bit sensor readout but the Xml file from the camera shows feature(s) of
<Feature Name="AcquisitionFrameRateAbs" Type="Float" Access="R/W">31.872511</Feature>
<Feature Name="PixelFormat" Type="Enumeration" Access="R/W">Mono8</Feature>
<Feature Name="SensorReadoutMode" Type="Enumeration" Access="R/W">Readout12Bits</Feature>
Which is the frame rate which Area Detector seems to acquiring at.
I am assuming that I would have to implement “SensorReadoutMode” to be able to get the expected FPS, or am I missing an existing parameter that might already do this?
Me
RE: Mako G-234B (6408) - Prosilica Area Detector question Mark Rivers
Prev: RE: EtherCAT newbie question Linda.Pratt
Next: problem using motor record and SNL Hovanes Egiyan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
Next: RE: Mako G-234B (6408) - Prosilica Area Detector question Mark Rivers
ANJ, 07 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
