1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Mako G-234B (6408) - Prosilica Area Detector question
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 9 Mar 2018 18:07:11 +0000
Hi Mark,
I have never seen that problem.  It seems strange that with PixelFormat=Mono8 it would be reading in 12-bit mode.  Can you set that to 8-bits with their Windows GUI software?  And if so does it revert to 12 bits when you power-cycle the camera?
It would probably be a good idea to expose the SensorReadoutMode feature in the EPICS driver.
It would also be a good idea to write a new driver based on their Vimba SDK, rather than old PvAPI SDK we are currently using J
Sent: Friday, March 09, 2018 9:37 AM
To: [email protected]; Mark Rivers <[email protected]>
Subject: Mako G-234B (6408) - Prosilica Area Detector question
Mark,
I recently deployed  a GigE camera Mako G-234B from Allied Vision with the Prosilica Area Detector but noticed a bit of oddness with the expected frame rate. The camera data sheet lists 41.2 FPS as the readout rate,10-bit sensor readout but the Xml file from the camera shows feature(s) of
<Feature Name="AcquisitionFrameRateAbs" Type="Float" Access="R/W">31.872511</Feature>
<Feature Name="PixelFormat" Type="Enumeration" Access="R/W">Mono8</Feature>
<Feature Name="SensorReadoutMode" Type="Enumeration" Access="R/W">Readout12Bits</Feature>
Which is the frame rate which Area Detector seems to acquiring at.
I am assuming that I would have to implement “SensorReadoutMode” to be able to get the expected FPS, or am I missing an existing parameter that might already do this?
Me
RE: Mako G-234B (6408) - Prosilica Area Detector question tom.cobb
Mako G-234B (6408) - Prosilica Area Detector question Mark Engbretson
Prev: RE: problem using motor record and SNL Mark Rivers
Next: Re: problem using motor record and SNL Hovanes Egiyan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Mako G-234B (6408) - Prosilica Area Detector question Mark Engbretson
Next: RE: Mako G-234B (6408) - Prosilica Area Detector question tom.cobb
ANJ, 12 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
